09-21-2018, 15:24 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | VIVO V9 1723 AND:8.1.0 SnapDragon 625 [MSM8953] BRUSH PATTERN LOCK & FRP D THANKS INFINITY-BOX TEAM |
The Following User Says Thank You to gracy_elec For This Useful Post: |
09-21-2018, 18:12 | #2 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Negeri Para Penipu
Member: 142211 Status: Offline Thanks Meter: 90 | what wrong with my step sir Card found : 948xxxxx , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... ERROR : Fail to init protocol! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : DEA139C2 ID_BLOCK_E : 00730004 ID_BLOCK_L : FA98BBB74193ED5AC0CCBA64EEB10E2B ID_BLOCK_L : B45497B0E02A5AC2B1FE42ECC62AA79E Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
09-22-2018, 09:55 | #3 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | SOLUTION FOR YOUR PHONe HELLO @not2link AS YOUR LOGS SAY YOUR CPU IS DIFFERENT YOUR CPU:SnapDragon 660 [MSM8956 Plus] MY CPU:SnapDragon 625 [MSM8953] SOLUTION FOR NOW LIKE MTK BOOT FILE CHANGE SAME PROCESS SO RIGHT NOW HARD HIDEN WORK FOR YOU TO REPLACE BOOT FILE IN BOOT FOLDER AND TRY TO CONNECT YOUR PHONE TO DO OPRATION GOOD LUCK |
09-22-2018, 10:19 | #4 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
Thanks in advance | |
