11-10-2018, 05:43 | #1 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1050365 Status: Offline Thanks Meter: 207 | Vivo V9 PD1730F Formate Failed Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 18194B86 ID_BLOCK_L : AF6E55B03BA2732FEB4D2FCF2B16AAF9 ID_BLOCK_L : F2B70DC030C2F152338C4C1DAA625725 Use CM2 Internal Loader Loader Sent! Initializing ... ERROR : FH Configuration failed! HINT : Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! With Loder Change Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 18194B86 ID_BLOCK_L : AF6E55B03BA2732FEB4D2FCF2B16AAF9 ID_BLOCK_L : F2B70DC030C2F152338C4C1DAA625725 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64AB Boot Ok! Brand : vivo ProdName : msm8953_64 ProdModel : vivo 1723 Device : msm8953_64 AndroidVer: 8.1.0 Manufact. : vivo SysPatch : OPM1.171019.011 DevComTime: 10/15/2018 11:29:28 AM USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:13 Reconnect Power/Cable! But Formate Failed Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 18194B86 ID_BLOCK_L : AF6E55B03BA2732FEB4D2FCF2B16AAF9 ID_BLOCK_L : F2B70DC030C2F152338C4C1DAA625725 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64AB Boot Ok! Format USER ... Format CACHE ... Format failed! Done! Elapsed: 00:02:38 Reconnect Power/Cable! With Memory Tool wipe User Data Operation : Memory Tool Init [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 18194B86 ID_BLOCK_L : AF6E55B03BA2732FEB4D2FCF2B16AAF9 ID_BLOCK_L : F2B70DC030C2F152338C4C1DAA625725 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64AB Boot Ok! Set default path : C:\InfinityBox\CM2QLM\phdata\ Ready! Operation : Erase Memory [ v1.16 ] Erase selected partitions [1] [0] Erase partition : USERDATA ProgStart : ret_auth=0 Erase Error , Prepare data error #0 , Check battery charge! Shutdown MemoryTool due fatal error ERROR : Flashing failed! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Phone Have Software Version PD1730F_EX_A_1.10.12 and Pattern Lock Downgrade not allowed If any one have same version please provide firmware link. Thanks |
