08-09-2017, 18:53 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Georgetown
Member: 455304 Status: Offline Thanks Meter: 417 | vivo xplay6 account remove Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 820 [MSM8996] ID_BLOCK_S : 75C819A2 ID_BLOCK_I : 009470E1 ID_BLOCK_L : 3185673ED6D94C9D8632E9CA5E6C5D99 ID_BLOCK_L : B700EAA195A829AACB92F6176ED11A88 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : SAMSUNG KLUDG8J1CB-B0B1 0800 UFS SectSize : 0x1000 --------------UFS Device Info-------------- UFS Total Active LU: 0x6 UFS wManufacturerID: 0x1ce UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x800f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x1 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to shawn4life For This Useful Post: |
08-09-2017, 19:02 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Make read with MemoryTool GTP from drive0,1,2,3,4,5. Total 6 files. Send all them for checking. |
03-17-2018, 08:10 | #4 (permalink) | |
Freak Poster Join Date: Jul 2013 Location: Sri lanka-matara
Member: 1989336 Status: Offline Sonork: 100.1652933 Thanks Meter: 13 | cant connect phone Quote:
bro my phone is not connected.device manger show qulcomm 9008 loader. pls help | |
03-17-2018, 08:35 | #5 (permalink) | |
Freak Poster Join Date: Jan 2017
Member: 2671513 Status: Offline Thanks Meter: 121 | Quote:
The Following User Says Thank You to dadarko For This Useful Post: |
