Old 03-28-2022, 19:48   #1 (permalink)
Member: 2911786
Thanks Meter: 22
Vivo y15 1901 destroyd preloader cant boot or flash
Operation : Identify [ v2.34 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM17)
MODE : BOOTROM
PORT : 17
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Cervino
TYPE : MODERN [RAPHAEL]
BROM : MEID : B24563F81E1A8C46328F740D0036B66B
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
BROM : SOCID : 44E3F38D2AA4A56B95D699448F27A78E125C8E3EB27B7FFF5C 21D5E8063ABEB7
BROM : SLA : Local Auth
BROM : SLA : Starting Auth
BROM : SLA : Auth Passed!
BROM : SEC : 0x000000E0
AGENT : 0_base : BASE_v2112 | Manual : Enabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMMC: CID : 90014A68433961503301C3D809C2B685
EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 : PRV : 0x01
EMMC: VEN : HYNIX : hC9aP3
EMMC: SNN : 3285715394 ( 0xC3D809C2 ) , MF : 11/2019
EMI : DEV : FireFly
EMI : SRC : preloader_k62v1_64_bsp.bin
EMI : CNT : 000E
EMI : Init EMI from INTERNAL DB
DA : SETUP EMI PARAMS FAILED!
ERROR : ABORT
Error : Fail to init protocol!
>>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device!
Reconnect Power/Cable!
Old 03-29-2022, 02:48   #2 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 4,933
Disable drivers signature enforcement
Install driver's from support area
Restart pc and repeat what result ??
Old 03-29-2022, 07:05   #3 (permalink)
GSM AR's Avatar
Member: 2608490
Thanks Meter: 861
Xiaomi Redmi 9C M2006C3MG
With Default SW Settings Same Error With me.
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34
Load IDBase v312457 Ok!
Update configuration ...
Operation : Reset Settings/Format FS [ v2.34 ]
Mode : SMART RESET
PTFN : MediaTek USB Port_V1632 (COM18)
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : MEID : B714D404077887326898E34C121ACF7B
BROM : SecLevel : 0x000000E7
BROM : SecMode : SBC+SLA+SDA+EXT
BROM : BOOTROM
BROM : SOCID : 28E9A10509ECE53181FED0DA074EA25265CF96EEF94C70B5F6 E05157AC73A85F
AGENT : 0_base : BASE_v2112 | Manual : Disabled
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMMC: CID : 13014E53304A3339441022988395C75D
EMMC: VEN : MICRON : OEM : 78 : ID : 53304A333944 : PRV : 0x10
EMMC: VEN : MICRON : S0J39D
EMMC: SNN : 580420501 ( 0x22988395 ) , MF : 12/2020
EMI : DEV : FireFly
EMI : SRC : preloader_k65v1_64_bsp.bin
EMI : CNT : 0009
ERROR : ABORT
Its Done with infinity FireFly after 2,3 tries.
Mode : SMART RESET
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : SOCID : 28E9A10509ECE53181FED0DA074EA25265CF96EEF94C70B5F6E05157AC73A85F
BROM : Sending FireFly
FireFly : Starting ...
FireFly : Init Core
FireFly : Core init done!
FireFly : Running : v05.05.05 on MT6765
FireFly : eMMC init passed!
        EMMC: CSD : D05F01328F5913FFFFFFFFEF964000A9
        EMMC: CSD : TEMP_WRITE_PROTECT: False
        EMMC: CSD : PERM_WRITE_PROTECT: False
        EMMC: EXTCSD : rev1.8 ( eMMC 5.1 )
        EMMC: EXTCSD [CONFIG] : 0x48,  0x02,  0x01
        EMMC: EXTCSD [PARTITION_CONFIG] : 0x48
        EMMC: EXTCSD [BOOT_BUS_WIDTH]   : 0x02
        EMMC: EXTCSD [RST_N_FUNCTION]    : 0x01
        EMMC: EXTCSD [PART_S_COMPLETED] : False
        EMMC: EXTCSD [SIZE] : Market    : 128 GB
        EMMC: EXTCSD [SIZE] : Actual    : 0x1D1F000000  [ 116.48 GB ]
        EMMC: EXTCSD [EOL] : EOL status : Normal  ( Less than 80% reserved blocks used )
        EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used
        EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              USER   : 0x1D1F000000 [ 116.48 GB ]
DA : USB : HIGH-SPEED
Boot done!
SmartInfo : 0x825657
Format Ok : RESET PROTECTION
Format Ok : USERDATA
Format Ok : CACHE
Done!
Elapsed: 00:01:30
The Following User Says Thank You to GSM AR For This Useful Post:
Old 03-29-2022, 08:35   #4 (permalink)
Member: 2911786
Thanks Meter: 22
i always setup my pc withdisbled driver sigature permanently
same drivers working 100 ok the whole day with almost 50 to 100 devices daily
Old 03-29-2022, 08:39   #5 (permalink)
Member: 2911786
Thanks Meter: 22
Mode : SMART RESET
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : FireFly
EMI : CNT : 0009
ERROR : ABORT
Mode : SMART RESET
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
FireFly : Init Core
        EMMC:
Boot done!
Format Ok : CACHE
Done!
Elapsed: 00:01:30
have you got your issue resolved or not
i received this device dead from a tech he said it was with most latest security build where brom is not workig so i tried with brand and model selection but still same no emi i tried with providing the backup of preloader/emi which i got from that tech the tool he used to flash had backup of preloader but still same then i tried to load the official preloader from the factory signed firmware still same any missing point or a lead is highly appreciated
Old 03-29-2022, 11:07   #6 (permalink)
Member: 2911786
Thanks Meter: 22
Mode : SMART RESET
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : FireFly
EMI : CNT : 0009
ERROR : ABORT
Mode : SMART RESET
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
FireFly : Init Core
        EMMC:
Boot done!
Format Ok : CACHE
Done!
Elapsed: 00:01:30
Thanx alot dear i got the point but still i am unable to flash the device but can get partition table flash each partition individually tried to init gpt by scatter and also tried to initialize the preloader but still getting same error cat init EMI.
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.18715 seconds with 7 queries
