06-30-2022, 15:53 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | vivo y33s v2109 DA : SYNC with DA FAILED! Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM175) MODE : BOOTROM PORT : 175 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 4BC21F4E446CA6661F14FE78E1785510 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 35E26854DE9EA2FEC5CD2BA17DCF061DB945CECA6637C9A99B 57BA0D6CFBC8C3 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI not found BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC with DA FAILED! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
07-01-2022, 04:22 | #3 (permalink) | |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Quote: Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM175) MODE : BOOTROM PORT : 175 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 4BC21F4E446CA6661F14FE78E1785510 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 35E26854DE9EA2FEC5CD2BA17DCF061DB945CECA6637C9A99B 57BA0D6CFBC8C3 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v05.05.05 on MT6768 FireFly : eMMC init passed! EMMC: CSD : 00000000000000000000000000000000 EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 00000000000000000000000000000000 EMMC: VEN : UNKNOWN [0x00] : OEM : 0 : ID : 000000000000 : PRV : 0x00 EMMC: VEN : UNKNOWN [0x00] : EMMC: SNN : 0 ( 0x00000000 ) , MF : 0/0 EMMC: EXTCSD : rev1.0 ( eMMC 4.0 ) EMMC: EXTCSD [CONFIG] : 0x00, 0x00, 0x00 EMMC: EXTCSD [PARTITION_CONFIG] : 0x00 EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x00 EMMC: EXTCSD [RST_N_FUNCTION] : 0x00 EMMC: EXTCSD [PART_S_COMPLETED] : False EMMC: EXTCSD [SIZE] : Market : NONE EMMC: EXTCSD [SIZE] : Actual : 0x00000000 [ 0 B ] EMMC: EXTCSD [EOL] : eMMC NOT support EOL info EMMC: DA : USB : HIGH-SPEED Boot done! Error : Failed to read initial info! Device Erased or Damaged >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! | |
07-01-2022, 04:29 | #4 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | mobile phone in working condition another person repair imei with chimera tool with tp after connect mobile phone show only mtk port |
