11-09-2018, 11:13 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: India
Member: 1860537 Status: Offline Sonork: 1657411 Thanks Meter: 39 | vivo y71 flash file needed i try to flash with many farmwere but not luck Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : EE5CE2F5 ID_BLOCK_L : 5EF9A241AC53E0BE7AB2BE5CB8E75B68 ID_BLOCK_L : 357AF007FD052C95FC498FD8779D90EA Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Flash Chain : 151 Flashing now Flashing : NON-HLOS.bin ProgStart : ret_auth=0 Flash Error , Prepare data error #0 , Check battery charge! ERROR : Flashing failed! INFO : Check previous message for more info! Reconnect Power/Cable! Loading firmware ... Loading 1 program definition file(s) ... Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : EE5CE2F5 ID_BLOCK_L : 5EF9A241AC53E0BE7AB2BE5CB8E75B68 ID_BLOCK_L : 357AF007FD052C95FC498FD8779D90EA Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Flash Chain : 152 Flashing now Flashing : NON-HLOS.bin ProgStart : ret_auth=0 Flash Error , Prepare data error #0 , Check battery charge! ERROR : Flashing failed! INFO : Check previous message for more info! Reconnect Power/Cable! Loading firmware ... Loading 1 program definition file(s) ... Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : EE5CE2F5 ID_BLOCK_L : 5EF9A241AC53E0BE7AB2BE5CB8E75B68 ID_BLOCK_L : 357AF007FD052C95FC498FD8779D90EA Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Flash Chain : 151 Flashing now Flashing : NON-HLOS.bin ProgStart : ret_auth=0 Flash Error , Prepare data error #0 , Check battery charge! ERROR : Flashing failed! INFO : Check previous message for more info! Reconnect Power/Cable! exat flash file needed |
11-09-2018, 22:04 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
12-09-2018, 16:06 | #3 (permalink) | |
Member: 1860537 Status: Offline Sonork: 1657411 Thanks Meter: 39 | Quote:
version.release:8.1.0 model:vivo 1724 cpu MSM8917 CPU:MSM8917 i don't have good file sir i need flash file of this phone i flash this file https://drive.google.com/uc?id=1wPgV...xport=download https://drive.google.com/file/d/1wPg...T-f1BXW44/view Last edited by viruscare; 12-09-2018 at 16:15. | |
