03-19-2018, 04:29 | #1 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2153016 Status: Offline Thanks Meter: 29 | Viwa light one _frp remove need help i have viwa light one with frp itrayed many boot files but no luck i searched for firmware did not find it ,,, can any one give boot files or link for firmware thankes to all |
The Following User Says Thank You to waleedwww For This Useful Post: |
03-19-2018, 04:46 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Hello @waleedwww,need help post logs here with out log unable to help Good Luck |
The Following User Says Thank You to gracy_elec For This Useful Post: |
03-19-2018, 17:08 | #3 (permalink) |
Member: 2153016 Status: Offline Thanks Meter: 29 | Card found : S/N : B66D1355 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 150100464531324D4207B74CDAE95479 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! thankes for help |
03-19-2018, 19:17 | #5 (permalink) |
Member: 2153016 Status: Offline Thanks Meter: 29 | Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! this log with original infinity da file & with out hold volume key |
03-20-2018, 14:22 | #6 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | HELLO @waleedwww, HERE IS YOUR DA FILE FOR YOUR CPU LINK : https://drive.google.com/open?id=19f...NduWZ8pG58hLHC GOOD LUCK |
03-21-2018, 04:17 | #8 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Hello link working recheck and post result log if problem not solved I will try Good Luck |
03-21-2018, 04:57 | #9 (permalink) |
Member: 2153016 Status: Offline Thanks Meter: 29 | THANKES AGAIN FOR REPLAY YOUR FILE DIDNOT WORK ,, HER IS LOG Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! SO I TRAID ANOTHER WAY BY SELECTING Infinix-X559__7.0__X559-H8015AB-N-170914V117 FLASH FILE IN FLASH TAPE AND YOU WELL NOT BELEAVE THIS IS THE LOG AFTER Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 150100464531324D4207B74CDAE95479 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM21E [eMMC] : FLASH_CID : 150100464531324D4207B74CDAE95479 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xCE3B27477609DB5038FD65EFB227942A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : VIWA ProdName : LIGHT_ONE ProdModel : LIGHT ONE Device : VIWA_LIGHT_ONE AndroidVer: 7.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-n0.mp2-V1.30_zechin6580.we.n_P36 SECURITY : IMEI_SW [1] : 353717090225527 IMEI_SW [2] : 353717090240526 BTMAC Addr : F2694665803C WiFi MAC : 74BADB67FE20 Done! Elapsed: 00:00:33 Reconnect Power/Cable! AND THIS FOR REMOVE FRP DONE Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 150100464531324D4207B74CDAE95479 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM21E [eMMC] : FLASH_CID : 150100464531324D4207B74CDAE95479 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xCE3B27477609DB5038FD65EFB227942A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! ALSO I READED THE FIRMWARE OF PHONE BUT PROGRAM CM2 SAYES THAT I CAN NOT FLASH THIS FILE TO ANOTHER PHONE ,,, THANK YOU MR : gracy_elec FOR YOUR HELP AND TIME Good Luck |
The Following 3 Users Say Thank You to waleedwww For This Useful Post: |
03-21-2018, 05:25 | #11 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Hello @waleedwww,I read the log is it true that start log of my da file plz re chk again Good Luck |
