08-25-2008, 14:44 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | >>> Voda 125 dead / Sim Blocked Recovered <<< After repair set got on but sim blocked. Then flashed the set with complete eeprom backup that was taken by software at the time, I first flashed the set.. Phone fully repaired and w/o sim blocked. Thanks Infinity Team >>> Loading file v.02... ZTE-125_repair_eeprom_complete_01[1].B1E.bin loaded COM1 [VCP0] selected Device: ZTE-125 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080823-174309.B1E.bin loading data... wrong database file: D:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.11 reading [eeprom-sec]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080823-174311.B1E.bin reading [eeprom-complete]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080823-174318.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 29 sec ----- Loading file v.02... ZTE-125_main_E-IN-P108A1V1[1].0.0B05_Jul-17-2007__VDF-P108A1B07-IN04_g3dBV2.0.B1M.bin loaded Loading file v.02... ZTE-125_LP_E-IN-P108A1V1[1].0.0B05_Jul-17-2007__VDF-P108A1B07-IN04_g3dBV2.0.B1P.bin loaded Device: ZTE-125 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080823-174447.B1E.bin loading data... wrong database file: D:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.11 reading [eeprom-sec]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080823-174448.B1E.bin reading [eeprom-complete]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080823-174450.B1E.bin reading [eeprom-dyn]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_20080823-174451.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Write Done Finished, Remove/Install battery now ! Time used: 77 sec ----- COM1 [VCP0] selected Device: ZTE-125 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080825-185928.B1E.bin loading data... wrong database file: D:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.11 reading [eeprom-sec]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080825-185930.B1E.bin reading [eeprom-complete]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080825-185932.B1E.bin reading [eeprom-dyn]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_20080825-185933.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 23 sec |
08-26-2008, 02:15 | #6 (permalink) |
No Life Poster Join Date: Sep 2005 Age: 59
Member: 185776 Status: Offline Thanks Meter: 73 | Mr.Zeel Zeel is telling first take back up from dead set.Second He flash with full files from support and repair eprom file.Then he chek the set,set shows with sim SIM BLOCKED.Third He write Eprom back up from dead set.OK. |
Voda 125 Dead after many tries to Unlock | dannyogolo | FuriousGold | 34 | 01-15-2009 21:56 |
>>> VODA V720 unlocked done by POLARBOX2 <<< ::: USER REPORT ::: | keaelite | PolarBox 3 | 0 | 12-12-2008 07:34 |
Vodafone 125,225 Sim blocked | Majey | Infinity-Box | 11 | 07-10-2008 10:55 |
>>> VODA 226 unlocked successfully using FG <<< | keaelite | FuriousGold | 6 | 05-26-2008 02:49 |
VDF 125 allways sim blocked | fethi | Infinity-Box | 1 | 04-05-2008 13:00 |
