07-18-2011, 09:26 | #1 (permalink) |
Insane Poster Join Date: May 2004 Location: Srilanka Age: 47
Member: 66429 Status: Offline Thanks Meter: 2 | vodafone 150 boot failure module v3.75 Device: Vodafone-150 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 chip: 0011:43A6:A00C status: 01 warning: unknown or damaged hardware boot packet size: 0400 error: bootcode load error: A0 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error: no any expected answer : wrong answer after chip cfi request number of flash chip/regions detected: 00/01 flash chip is unknown or damaged. Fault reasons: 1. flash chip is damaged: replace or resolder/reball flash chip 2. hardware is damaged: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 32 sec Remove/Install battery now ! |
07-18-2011, 13:48 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | Please bro, try to unlock using latest mmodule from support. |
The Following User Says Thank You to KYEJUSA For This Useful Post: |
07-18-2011, 20:16 | #3 (permalink) | |
Do not use HALF YEAR old software ! | |
09-08-2011, 12:56 | #4 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | COM69 [VCP5] selected module v3.99 Device: Vodafone-150 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:4266:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 8C22F60000000D:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 00390000/00068000 TCL-ID identification version: 16H provider: 150X-2AVDKE1 customization: CW16CD60 customization: XW16CD60 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 00390000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XW16CD60 customization name adjusted flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: 8C22F60000000D:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 8C22F60000000D:2BEA0000000000 Finalization Done file saved: C:\InfinityBox\MModule\backup_security\Vodafone-150_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W0 8_36_SP1_V28_F1__system_log__00000000_20110908-145438.B0X.bin Finished, time used: 2 min 2 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
8810 & 8210 Phone NOT respond! (Load Boot data) | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-25-2001 14:47 |
F_loaders.bin and Boot.bin .. . | micklong | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-29-2001 14:49 |
Phone not respond! (Load boot data) Need a help ! | SashaM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-23-2001 02:10 |
http://www.gsmfactory.com (more than 150 Mo of GSM Software) | glouglou | GSM Mobile Links | 0 | 07-03-2000 00:30 |
Nokia Datasuite Connection Failure | Judesp | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-27-1999 09:36 |
