04-30-2009, 08:43 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: In Think
Member: 503334 Status: Offline Sonork: 100.1590885 Thanks Meter: 173 | vodafone 225 dead by flash module v1.65 Device: Vodafone-225 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 230400 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... sw version: -HU-P108A2V1.0.0B03 VDF-P108A2B07-Hu-HU03 g3dBV2.0 04.12.00 18.2 Check hardware Done Check parameters ... Check parameters Done backup critical area ... backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware repair write error [00401000:0800]... error: write failed[00400000] Write Failed Finished, time used: 25 sec Remove/Install battery now ! before flash set on please help infinity how to recover my set |
04-30-2009, 15:22 | #4 (permalink) |
Member: 503334 Status: Offline Sonork: 100.1590885 Thanks Meter: 173 | hardware ok not hardware problem problem solved by software see preducer 1st i salect model Digibee-G240 flash with zte 225 flash file after flash sp unlock my set recovered sucssecfully ==== log: [4/30/2009 3:59:57 PM] ==== COM3 [VCP0] selected module v1.65 Device: Digibee-G240 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-G240_eeprom-static_20090430-160012.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-G240_eeprom-security_20090430-160012.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-G240_eeprom-complete_20090430-160014.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Erasing: FFS-2/File system Writing: FFS-2/File system Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 134 sec Remove/Install battery now ! ==== log: [4/30/2009 4:02:19 PM] ==== COM3 [VCP0] selected module v1.65 Device: Digibee-G240 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-G240_eeprom-static_20090430-160233.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-G240_eeprom-security_20090430-160234.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-G240_eeprom-complete_20090430-160235.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-G240_lock-area_20090430-160238.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 21 sec Remove/Install battery now ! |
The Following User Says Thank You to Pragyan_Gehlot For This Useful Post: |
09-19-2009, 13:26 | #9 (permalink) | |
Banned Join Date: Jan 2007 Location: India Age: 34
Member: 432364 Status: Offline Thanks Meter: 270 | Quote:
B.r. | |
09-19-2009, 14:11 | #10 (permalink) | |
No Life Poster Join Date: Sep 2009 Location: My Lappy Age: 37
Member: 1115989 Status: Offline Sonork: 9905677786 Thanks Meter: 3,202 | do not take tensio Quote:
hey do not take tension its just miss of file use original file . after it you will success . actually i also suffered from it. but after few moment i got success. | |
09-26-2009, 09:02 | #12 (permalink) |
Member: 432364 Status: Offline Thanks Meter: 270 | Problem solved by flash this file ZTE-225_main_lp_VDF-P108A2B07-Pt-PT04_Sep-22-2008.B1M thx |
The Following 3 Users Say Thank You to ..::Sunil::.. For This Useful Post: |
vodafone 225 dead when flash | rajtelecom | Infinity-Box | 13 | 06-01-2010 14:41 |
vodafone 225 dead after flash... | jagdish1747 | Infinity-Box | 8 | 02-12-2010 18:27 |
Vodafone 225 dead la unlock.... | v11 | FuriousGold | 5 | 02-03-2010 18:20 |
zte vodafone 225 dead after flash | ahmedasmet | Infinity-Box | 3 | 10-30-2008 15:14 |
vodafone 225 manufactured by zte ....unlock ?? | jokkergsm | ZTE | 26 | 01-17-2008 14:09 |
