04-12-2008, 06:53 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: AnyClient Age: 44
Member: 10485 Status: Offline Sonork: 100.66876 Thanks Meter: 396 | vodafone 226 cant unlock !!! Code: Loading data, wait... [Infinity Box] v1.43 S/N: ***x:***x Wait... Current model: Vodafone 226 Ready COM26 [VCP0] selected Device: Vodafone 226 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: EBI_II EBI_II_060807_1127 060807_1127 Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080412-112038.B1E.bin loading data... wrong database file: D:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.14 reading [eeprom-sec]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080412-112042.B1E.bin reading [eeprom-complete]... file saved: D:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080412-112048.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 50 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
07-02-2008, 12:39 | #9 (permalink) |
No Life Poster Join Date: Jan 2005 Location: IN YOUR HEART
Member: 109163 Status: Offline Thanks Meter: 75 | i have same problem. if enter unlock code " wrong code, you may try after 2 minut" COM17 [VCP0] selected Device: Sagem-my226 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH_290607_1101 290607_1101 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-sta_20080702-112931.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-sec_20080702-112933.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-complete_20080702-112934.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 34 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
07-02-2008, 17:12 | #11 (permalink) |
Member: 109163 Status: Offline Thanks Meter: 75 | br mobi-fix i readed all this thread, and also iknow 00000000 codes its working in somecase. if not supported what i will do? ur reply not a good solution to me.. and you thinking you did a hardwork. |
07-02-2008, 21:26 | #13 (permalink) | |
Are you really need this explanation ? Ok, it's not hard explanation: In fact you can enter any code (any, this means 1234... or 000... or 98765... or any other that you want) and phone will be unlocked. But to avoid problem with users and to avoid users misunderstanding we have made more that clear instruction what to do and what kind of code user must enter. Please, confirm, is my current explanation enough clear ? | |
11-03-2008, 10:50 | #14 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Kolkata,Kathmandu,
Member: 306096 Status: Offline Sonork: 100.1585877 Thanks Meter: 255 | Quote:
Sir did your set is unlock? Ya not? umadineshdas | |
11-04-2008, 10:00 | #15 (permalink) | |
Thanks Infinity | |
Vodafone 226 Fm Unlock 10000000000000%....... | DYNET | Infinity-Box | 37 | 08-20-2010 15:46 |
Sagem My150x/vodafone 226/my401z Unlock | damabib | SMTi | 17 | 09-19-2009 07:19 |
vodafone 226 cant unlock | maximas007 | SAGEM JTAG UNLOCKER | 2 | 03-20-2009 08:54 |
vodafone 226 to unlock-counter blocked-how unlock | zonetrichur | Infinity-Box | 2 | 08-03-2008 18:48 |
Vodafone 226 not UNLOCK | guedes666 | FuriousGold | 5 | 04-14-2008 23:59 |
