08-13-2010, 13:45 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | Ajanta A2100 test power on! So am i try to repair with infinity but failed. pls share idea Flashing logs : Code: COM11 [VCP0] selected module v1.78 Device: Ajanta-A2100 Checking data, wait... Action: write flash write: Firmware Ajanta-A2100_Mar-14-2008.B1M.bin skip: FFS-1/Customization skip: Language Pack skip: Graphics Pack skip: FFS-2/File system skip: Eeprom Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .00 ULC2GL 0 A 0 q Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_eeprom-static_20100813-180527.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_eeprom-security_20100813-180527.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_eeprom-complete_20100813-180529.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 2 min 18 sec Remove/Install battery now ! UNLOCKING LOGS: Code: COM11 [VCP0] selected module v1.78 Device: Ajanta-A2100 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .00 ULC2GL 0 A 0 q Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_eeprom-static_20100813-180849.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_eeprom-security_20100813-180849.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_eeprom-complete_20100813-180850.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_lock-area_20100813-180900.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 38 sec Remove/Install battery now ! Code: COM11 [VCP0] selected module v1.78 Device: Ajanta-A2100 Checking data, wait... Action: "repair imei" new imei: 355862010000002 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .00 ULC2GL 0 A 0 q Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_eeprom-static_20100813-180947.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_eeprom-security_20100813-180947.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_eeprom-complete_20100813-180949.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_imei-area_20100813-180954.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_lock-area_20100813-181004.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found imei found #2 Check memory Done Write ... Erasing: imei-area Writing: imei-area Erasing: lock-area Writing: lock-area Erasing: eeprom-security Writing: eeprom-security Write Done Finished, time used: 55 sec Remove/Install battery now ! Finished THANK YOU!! |
The Following User Says Thank You to Riteshgpt60 For This Useful Post: |
08-18-2010, 09:57 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,933 | It's not a problem with unlock/imei but it's a problem with eeprom. We do not have any eeprom files for this model in support area yet, so if somebody can read eeprom and send to us ([email protected]) it will be good. Also, TEST POWERON may be a result of damaged hardware (f.e. water inside). |
08-19-2010, 14:15 | #3 (permalink) |
Member: 1086393 Status: Offline Thanks Meter: 771 | hi, Thank YOU!!!! All done. Code: COM7 [VCP0] selected module v1.78 Device: Ajanta-A2100 Checking data, wait... Action: write flash skip: Firmware skip: FFS-1/Customization skip: Language Pack skip: Graphics Pack skip: FFS-2/File system write: Eeprom Ajanta-A2100_eeprom-complete_20100819-181400.B1E.bin Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .00 ULC2GL 0 A 0 q Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_eeprom-static_20100819-184316.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_eeprom-security_20100819-184317.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A2100_eeprom-complete_20100819-184324.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 32 sec Remove/Install battery now ! Also sended to ([email protected]) |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
