Old 05-01-2008, 17:06   #1 (permalink)
williamvirk's Avatar
Member: 320105
Thanks Meter: 18
LG KG370 successfully unlocked
LG KG 370 successfully unlocked with code read option THANKS INFINITY TEAM
COM4 [VCP0] selected
Device: LG KG370
Checking data, wait...
Action: unlock
read unlock codes
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 00EC:257E
Connecting Done
Check hardware...
flash chip supported
sw version: ULC2GL AUSTRALIA KG370 P16 FL 61 V10a 505-02 VIR FEB 15 20
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KG370_eeprom-sta_20080501-172944.B1E.bin
loading data...
data loaded
imei: 35297702405886200
reading [eeprom-sec_35297702405886200]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KG370_eeprom-sec_35297702405886200_20080501-172948.B1E.bin
reading [eeprom-complete_35297702405886200]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KG370_eeprom-complete_35297702405886200_20080501-172956.B1E.bin
backup critical area Done
Check memory...
loading data...
data loaded
code: 65183141
Finished, Remove/Install battery now !
Time used: 26 sec
Old 05-01-2008, 18:34   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Thank you very much for good test report !
Old 05-01-2008, 18:58   #3 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
good work. good infinity box. thanks for good test report.
LG CU500v successfully unlock fasel FuriousGold 2 05-30-2008 07:26
LG KG275 Successfully Unlock in Inifity ASHRIFF Infinity-Box 10 05-05-2008 17:43
LG KG110 successfully unlock by hwk alamgir80 HWK 10 04-12-2008 11:29
2 Pieces of LG KE970 successfully unlocked ! Spax FuriousGold 4 04-09-2008 17:07
LG KG280 Successfully Unlocked by Furious Gold zLer FuriousGold 7 01-31-2008 07:45
Page generated in 0.18637 seconds with 9 queries
