Vodafone 226 unlock 100% ok use pin 1gnd,7rx,8tx. COM1 [Serial0] selected Device: Vodafone 226 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Vodafone 226_eeprom-sta_20080430-123404.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Vodafone 226_eeprom-sec_20080430-123410.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Vodafone 226_eeprom-complete_20080430-123416.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 82 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
Thank you very much for good test report ! |
i also tested all is ok |
