10-30-2006, 21:18 | #1 (permalink) |
No Life Poster Join Date: Jan 2006
Member: 219015 Status: Offline Thanks Meter: 42 | C156 restart problem 1. main-C155_0.4.84_Main.1FM, LP-C155_0.4.84_LP12_De_Ru_Ukr.1FP, flex-C155_Flex_90_61_M304.1FF. After flesh I switch on phone but it is light keypad lights only. 2.After I flash it with flesh file main-C157_1.4.88_Main.1FM, LP-C157_1.4.88_LPA3_Indonesia_Tagalog_Th_Vn.1FP, flex-C157_Flex_90_61_J009.1FF eeprom-C155_repair_eeprom_03.1FE I switch on phone it is switched OK but with restart problem After I wont flash some flash files but I have all time this message: COM5 selected Action: Flash Write: Firmware Write: Flex Write: Language Pack Write: Eeprom "Smart Write" active Device: C155,C156,C157 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW ver: 5 HW ver: LP ver: LP12_C155_0484 Flex ver: FLEX_90_61_M304 Check Flash-1 Done Check Flash-2... Check Flash-2 Done Write... Writing: Firmware Safe mode active retry[01] at: 00020000 retry[02] at: 00020000 retry[03] at: 00020000 retry[04] at: 00020000 retry[01] at: 00030000 retry[02] at: 00030000 retry[03] at: 00030000 retry[04] at: 00030000 retry[01] at: 00040000 retry[02] at: 00040000 retry[03] at: 00040000 retry[04] at: 00040000 retry[01] at: 00050000 retry[02] at: 00050000 retry[03] at: 00050000 retry[04] at: 00050000 this time I press stop button Write Done Failed ! Finished Remove/Install battery now ! Time used: 214 sec |
05-30-2008, 07:41 | #4 (permalink) |
Freak Poster Join Date: Nov 2001 Location: bandung
Member: 7103 Status: Offline Thanks Meter: 48 | Infinity connection mode: 00 C156 restart problem COM1 [Serial0] selected Action: read eeprom Device: C155,C156,C157 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 |
06-12-2008, 05:18 | #9 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | use oregenal usb cable for Motorola i have that cable and never face that problam in my life or cheq your com port properly in your logs i think u dont select your com properly every time u have to select com when u run different module for example when u run china merecal u have to select com and after that if u run pana01 module then u should select com again |
cect v180 restarting problem but after ffs same problem | shripalkawdia | Infinity-Box | 9 | 05-09-2009 02:06 |
LG KE800 restart problem but 1st problem is bluetoth | Freshbol | Infinity-Box | 4 | 02-13-2008 20:14 |
N95 had restart problem and now have problem with sensor key | Supermen! | Infinity-Box | 2 | 11-23-2007 09:23 |
6270 startup restarting problem help big problem | vinay_sharma | Nokia Hardware & Hardware Repair | 5 | 07-07-2007 22:06 |
v50 restart problem | Siemens man | Motorola Old Legacy (EMMI) | 2 | 07-24-2003 18:23 |
