02-25-2008, 12:54 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,537 | hello! are you sure to start from flashing? Format FFS is not helpful? please try format and post here a log. if will not we will advice you a flash file basing on log you will provide |
03-02-2008, 17:42 | #3 (permalink) |
Crazy Poster Join Date: May 2005 Age: 45
Member: 145941 Status: Offline Thanks Meter: 0 | FORMAT FFS is not solved my problem.......the phone just start up so die like w210 i read eeprom from healt phone............so i flashing to error phone,it is not solved my problem..........phone is die so i read fullflash from healt phone.......so i flashing to error Phone,it is not solved my problem..........phone is die know i format ffs is failed help me mr.infinity.............sorry i can reply your posting right now because the web is error..........thank's |
06-10-2008, 09:32 | #5 (permalink) |
Crazy Poster Join Date: Sep 2007 Location: banjarmasin-indonesia
Member: 588792 Status: Offline Thanks Meter: 14 | hitech h38 i have one too...hi tech h38 die format succses still die if backup flash..have picture like this... can't detect eeprom/ffs area do you want to use standart ffs address : 00E00000? if you are not sure that standart address is correct 1.press "NO" and terminate current operation 2.make flash backup for emergency case 3.repeat required operation |
06-10-2008, 12:08 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,537 | hello mr. danisya! if phone died- they only way to reapir it is to flash it with same firmware version as it was originaly. please open operation.log file which is stored in chinese miracle folder. find first operation which you did with this set and there you will see it's original version. pick flash file according this version and perform flashing |
06-11-2008, 12:51 | #7 (permalink) |
Major Poster Join Date: Jun 2005 Age: 42
Member: 153080 Status: Offline Thanks Meter: 1 | i've got this problem too after formating this is the log Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.10 S/N: ***x.zzzz Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM7 [VCP6] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... chip: 0031:95D6:B952 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: UPU25U26V03B54 Version: U26_06B_HW detecting structure #2... done 44 byte(s) read imei: 35688900763956 connection Ok building list... done items to clear: 168 137 of 168 items cleared 0 items remains Finished, time used: 170 sec now phone can't on normaly, it's only show hitech logo then off again. what should i do now? please help... |
how to flash a52? | fuadgsm | E-Gold Based Phones | 1 | 03-29-2010 18:48 |
How to flash SGH B520.-URGENT- | prashantvrm | Samsung Flashers, Software, Firmware. | 1 | 03-29-2010 13:24 |
how to flash e250i | adda2004 | Samsung Flashers, Software, Firmware. | 0 | 03-29-2010 12:26 |
how to flash 1st cpu & how to flash 2nd cpu | kasim | Infinity-Box | 4 | 03-15-2008 11:09 |
