Old 02-23-2009, 07:01   #1 (permalink)
gsm-world's Avatar
Member: 582790
Thanks Meter: 378
Vodafone-228 unlock Done
OM14 [VCP0] selected
module v1.60
Device: Vodafone-228
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
sw version: -HU-P108C1V1.0.0B06 Jun 17 2008 Jun 17 2008 11 25 35 VDF-P108C1B
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_eeprom-static_20090207-140028.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_eeprom-security_20090207-140029.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_eeprom-complete_20090207-140030.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-228_lock-area_20090207-140034.B1E.bin
backup critical area Done
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 23 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to gsm-world For This Useful Post:
Old 02-23-2009, 19:55   #2 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 211
module v1.60
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
Old 02-24-2009, 11:38   #3 (permalink)
Member: 625563
Sonork: Niceguy
Thanks Meter: 36
how can i unlock 125 with infinty and are we select the pinfinder with infinty or only infinty plz help me brothers i am new user the infity.thanks in advance.
Old 03-26-2009, 06:10   #4 (permalink)
thanhhieuqb's Avatar
Member: 478447
Thanks Meter: 9
I unlock vodafone 228 ok but inside sim card is keyboad hang . help me please . thanks !
Old 03-26-2009, 08:32   #5 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,817
Did you tried to make 112/emergency call without sim card ?
What is the results ?
Old 03-26-2009, 09:29   #6 (permalink)
Member: 478447
Thanks Meter: 9
I try 112 call without sim , emergency call ............ ending call !
Old 04-27-2009, 21:09   #7 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
someone has any idea when the situation is such that it wont allow entering 12345678 (like keypad is jammed but 112 can be done) pls?
thanks
Old 04-27-2009, 21:38   #8 (permalink)
Member: 11325
Thanks Meter: 266
sorry for my blunder..... i was using and older version..... did not realise that
used version 1.65 and all is ok .... please check the log..... phone is branded from Voda UK and NOT SFR France.
COM4 selected
module v1.65
Device: SFR-228
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
sw version: VDF-P108C1B02-FrRoBgElHu-RO02 g3yBV2.0 Dec 29 2007 09 01 39 09 0
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\SFR-228_eeprom-static_20090427-213528.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\SFR-228_eeprom-security_20090427-213529.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\SFR-228_eeprom-complete_20090427-213531.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\SFR-228_lock-area_20090427-213536.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 27 sec
The Following User Says Thank You to Burnt Cobba For This Useful Post:
Vodafone 228 unlock successfully with infinity! kmaxmax Infinity-Box 4 01-04-2010 20:03
vodafone 228 unlock a.majeed SMTi 0 07-29-2009 12:53
12/03/2008 Huawei T201, Vodafone 227, Vodafone 228 Unlock/Flashing !!! .:hack3r2k:. FuriousGold 74 01-16-2009 00:39
Vodafone 228 Unlocked OK by Infinity box using Pinfinder MDK23 Infinity-Box 6 01-10-2009 18:04
Vodafone 228 unlocked successfully wykie PolarBox 3 0 05-21-2008 21:08
Page generated in 0.29285 seconds with 8 queries
