Old 09-07-2010, 05:00   #1 (permalink)
sukhdeep's Avatar
Member: 348478
Thanks Meter: 62
vodafone 340 dead after unlock
vodafone 340 dead after unlock. i need new firmware ver. FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_42.BIN
if anybody have this phone please read fullflash and upload
Old 09-07-2010, 05:34   #2 (permalink)
shamshad quresh's Avatar
Member: 898041
Sonork: 100.1593459
Thanks Meter: 549
please send unlocking log here.......
Old 09-07-2010, 10:44   #3 (permalink)
Member: 1043909
Thanks Meter: 60,911
What was the problem with unlock exactly ?
Old 09-09-2010, 06:37   #4 (permalink)
sukhdeep's Avatar
Member: 348478
Thanks Meter: 62
sir we do unlock with standerd fast tab thats why no backup was saved
here is log
module v3.44
Device: Vodafone-340
Checking data, wait...
Action: "sp-unlock"
unlock method: standard fast
Unlock procedure can be faster if you skip ffs/eeprom area backup procedure.
Do you want to disable ffs/eeprom backup ?
ffs/eeprom backup disabled
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001303:A00E
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.44, database date: 14.06.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 05
sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_42.BIN
project-id: BM35A1.V2.22.M00.02.42, 00000000
code offset: 00000000
ffs offset/size [01]: 00B80000/00480000
TCL-ID is absent
ffs/eeprom address assigned: 00B80000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: BM35V2MP_MA7V28JR9BT71SDRPK7GS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
lock area found
lock area found
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: lock-area-1
Write: lock-area-4
Write Done
====> Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42__system_log__00000000_20100906-185939.B0X.bin
Finished, time used: 1 min 52 sec
Remove/Install battery now !
Old 09-09-2010, 07:20   #5 (permalink)
dilshann's Avatar
Member: 1093564
Thanks Meter: 326
here is log
module v3.44
Action: "sp-unlock"
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001303:A00E
status: 01
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
area1 is valid
area2 is valid
area3 is valid
area4 is valid
lock area found
lock area found
====> Write ...
Write: lock-area-1
Write: lock-area-4
Write Done
Finalization Done
do not use unlock method: (standard fast)
next time use unlock method: (smart fast) unlock ok ....
Old 09-09-2010, 07:36   #6 (permalink)
Parminder Singh's Avatar
Member: 476739
Thanks Meter: 507
no problem this is normal prob..
use
MModule_v3.53
and flash
with file
Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42_2010-01-11_En.B0M.bin
in supprt area
good luck
The Following User Says Thank You to Parminder Singh For This Useful Post:
Old 09-09-2010, 07:39   #7 (permalink)
Crazy Poster
Member: 916261
Thanks Meter: 14
yes sir hi use old m module
good work
MModule_v3.53 tray to this or higher
The Following User Says Thank You to gsm2kaka For This Useful Post:
Old 10-14-2010, 11:23   #8 (permalink)
Member: 65945
Sonork: 100.1606747
Thanks Meter: 15
vodafone 340
use
MModule_v3.53
and flash
with file
in supprt area
good luck
hi
this model unlocked in 3.62 m module
with out any problem
Old 12-22-2010, 09:42   #9 (permalink)
Member: 87364
Thanks Meter: 63
I can`t rapair my Vodafoen 340 after unlock is dead Then I write firmware:
Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 23_M00_02_35_En_Nl_Fr_De.B0M
and
Vodafone-340_ffs_03.B0E
Vodafone-340_ffs_04.B0E
and nothing
Log:
COM1 selected
module v3.62
Action: "sp-unlock"
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:1403:A001
status: 01
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
rom info structure: [standard] type (05)
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
area1 is valid
area2 is valid
area3 is valid
area4 is valid
reading: Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42__ffs...
file saved: C:\Program Files\InfinityBox\MModule\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42__ffs_20101221-131601.B0E.bin
detection procedure, wait...
detection procedure completed
error: phone is not locked or unknown eeprom
====> Write ...
Write: ffs
Write Done
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42__system_log__00000000_20101221-131928.B0X.bin
Finished, time used: 11 min 33 sec
Please help me.
Old 01-06-2011, 17:53   #10 (permalink)
Member: 7844
Thanks Meter: 182
i got infinty and vodafone 340 to unlock .... how can i unlock it without killing it ?
Old 02-01-2011, 15:29   #11 (permalink)
Member: 270936
Thanks Meter: 33
I also stuck up with the same problem, dead after unlocking with standard fast , tried somany tries and got result by flashing this version Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 23_M00_02_35_En_Nl_Fr_De.B0M , phone alive now and unlocked after that without any problem .
Old 02-15-2011, 10:45   #12 (permalink)
rashel.com's Avatar
Member: 460857
Thanks Meter: 804
infinity box unlock dene......
Old 02-24-2011, 09:26   #13 (permalink)
Member: 812328
Thanks Meter: 23
can anyone have back up files
of vodafone 340?
Old 02-24-2011, 11:48   #14 (permalink)
Member: 1043909
of vodafone 340?
You can download 340 flash files from Infinity-Box support area.
Old 02-14-2012, 12:45   #15 (permalink)
Member: 1590039
Thanks Meter: 20
vodafone 340
xxxxxx
sn b34000a600fc019l
unlock code???????????????
The Following User Says Thank You to khoykhoy20 For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:06
Page generated in 0.29598 seconds with 9 queries
