07-19-2011, 10:13 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: colombo Age: 40
Member: 645987 Status: Offline Sonork: 100.1612601 Thanks Meter: 112 | vodafone 351 unlock problem module v3.97 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-351 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E04 Date: 2000.00.00 Version: 1.0 Version: ES-VF-UK9-P130A10V1.0.4B01 Version: 09BZTENJ53_09B 115 byte(s) read imei: 3518470 connection Ok 216 byte(s) read reading data... reading data #2... building new data... writing data... 204 byte(s) read reading data... 852 byte(s) read building new data... warning: unknown lock version: 54030000 error: data is invalid Finished, time used: 8 sec Remove/Install battery now ! |
07-19-2011, 10:53 | #3 (permalink) | |
Please, try to make "read unlock" codes operation. Waiting for your results and operation log. | |
07-19-2011, 15:28 | #5 (permalink) |
Member: 645987 Status: Offline Sonork: 100.1612601 Thanks Meter: 112 | COM4 [VCP0] selected module v3.97 Action: read unlock codes unlock method: read codes Model: Vodafone-351 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E04 Date: 2000.00.00 Version: 1.0 Version: ES-VF-UK9-P130A10V1.0.4B01 Version: 09BZTENJ53_09B 115 byte(s) read imei: 35184700858270 connection Ok 216 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 204 byte(s) read reading data... reading data #2... 852 byte(s) read warning: unknown lock version: 54030000 error: operation failed ! Finished, time used: 18 sec Remove/Install battery now ! i have read full flash file & eeprom. here it's down link https://rapidshare.com/files/2049869...140956.B0M.bin https://rapidshare.com/files/1529499...142036.B0M.bin |
The Following 3 Users Say Thank You to nifboy For This Useful Post: |
07-22-2011, 08:15 | #7 (permalink) | |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | Quote:
COM233 [VCP0] selected module v3.97 Action: read unlock codes unlock method: read codes Model: _Autodetect MT6253 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E04 Date: 2000.00.00 Version: 1.0 Version: ES-VF-ES9-P130A10V1.0.4B01 Version: 09BZTENJ53_09B ==================== New firmware found (v.3.97, database date: 17.07.2011): ES-VF-ES9-P130A10V1.0.4B01 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 0 1 2 3 4 6 7 8 9 10 11 12warning: wrong packet cs 13 21 22 23 24 25 27 28 29 30 31 32 33 34error: detection failed (26 tries), read flash and send to support connection Ok detecting structure #1... 1 3 4 6 7 8 9 11 14 16 17 19 21 23 24 26 27warning: wrong packet cs 31 34 36 37 39error: detection failed (21 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 20 sec Remove/Install battery now ! | |
07-27-2011, 08:54 | #8 (permalink) |
Member: 645987 Status: Offline Sonork: 100.1612601 Thanks Meter: 112 | vodafone 351 unlock done COM4 [VCP0] selected module v3.98 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-351 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E04 Date: 2000.00.00 Version: 1.0 Version: ES-VF-UK9-P130A10V1.0.4B01 Version: 09BZTENJ53_09B 115 byte(s) read imei: 3563400 connection Ok 216 byte(s) read reading data... reading data #2... building new data... writing data... 204 byte(s) read reading data... 852 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
07-27-2011, 19:11 | #11 (permalink) |
No Life Poster Join Date: Sep 2005 Location: UK, London Age: 35
Member: 177235 Status: Offline Sonork: 111568 Thanks Meter: 138 | COM10 [VCP0] selected module v3.98 Action: read unlock codes unlock method: read codes Model: Vodafone-351 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 16 sec Remove/Install battery now ! hi, having trouble with smart method and read codes same |
07-30-2011, 07:18 | #14 (permalink) | |
Model: Vodafone-351 | |
08-05-2011, 13:10 | #15 (permalink) |
Member: 177235 Status: Offline Sonork: 111568 Thanks Meter: 138 | COM10 [VCP0] selected module v3.99 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-351 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 21 sec Remove/Install battery now ! i m using the cable which goes in the phone micro-usb, not solder points? same cable as v340, is that correct? |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
