05-04-2010, 10:39 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Live in your Heart
Member: 71045 Status: Offline Thanks Meter: 19 | Vodafone 541 need help?????? vodafone 541 come fro unlocking unlock done but does not power on i read the forum and try to recover with every method following firm ware from support applied but still power on on logo and black screen and nothing 708X-2EVDPT1-117B_XN17FG72_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MA UI_08A_W08_40_SP1_V32_2009-09-10_En_Fr_Es_De_Pt_Vodafone-541.B0M.bin 11.6 MB 2009-Dec-21 708X-2EVDRO1-17C_XN17FP82_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-09-16_En_Hu_It_Ro_De_Vodafone-541.B0M.bin 11.7 MB 2010-Feb-03 708X-2FVDES1-17C_XN17FE82_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-09-16_En_Es_Galician_Basque_Catalan_Vodafone-541.B0M.bin 11.4 MB 2009-Nov-19 708X-2FVDGB1-17B_XN17FC75_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-09-10_En_Fr_Es_It_De_Vodafone-541.B0M.bin 11.6 MB 2009-Nov-18 708X-2FVDHU1-17C_XN17FJ83_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-09-16_En_Hu_Ro_Cz_Sk_Vodafone-541.B0M.bin 11.7 MB 2009-Nov-19 25 Files - 1 Folders COM6 [VCP0] selected module v3.25 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware 708X-2EVDPT1-117B_XN17FG72_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MA UI_08A_W08_40_SP1_V32_2009-09-10_En_Fr_Es_De_Pt_Vodafone-541.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs enhanced security fix enabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7903:A00A status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is damaged, recalculation required rom info detection finished device-id: F8CEECD2 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 01800000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished security area (sec info, part #1) size is incorrect: E1530000 sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished security area (sec info, part #1) size is incorrect: E1530000 sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is valid area3 is valid area4 is invalid number of sec info areas: 3 detecting firmware version... firmware version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN detecting firmware build... ........................................ firmware build: mMAUI.08A.W08.40.SP1.V32JRDSZ25_08A_HW2009-09-1611-33 detecting product-id... .................................................. .................................................. ............................ done detecting languages... .................................................. ...................... language parameters detected detected languages: En Es Galician Basque Catalan Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35400703510353 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is present: 00020000 rom info relocation detected startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: F:\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_F8CEECD2_E8F450A0_20100504-141544.B0X.bin Area: Firmware flash: 98006F00000003:09EA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation.....................region counter set: 01 security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization: SN17B140 error: customization name is unknown error: can't read customization version error: can't calculate security area (sec info, part #2), existing data will be used Check support area for updates ! security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................region counter set: 01 security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization: SN17B140 error: customization name is unknown error: can't read customization version error: can't calculate security area (sec info, part #2), existing data will be usedCheck support area for updates ! security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................region counter set: 01 security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done ====> Finalization ... Finalization Done file saved: F:\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_F8CEECD2_E8F450A0_20100504-142926.B0X.bin Finished, time used: 15 min 45 sec Remove/Install battery now ! i need help to recover this hand set any way infinity team thanks & regards Zafar Janjua |
05-04-2010, 11:52 | #2 (permalink) |
No Life Poster Join Date: Dec 2007 Location: egypt
Member: 648590 Status: Offline Thanks Meter: 267 | error: customization name is unknown error: can't read customization version error: can't calculate security area (sec info, part #2), existing data will be used use Device: Alcatel-708X, 708A v-MModule_v3.37 |
05-04-2010, 13:02 | #4 (permalink) | |
Member: 71045 Status: Offline Thanks Meter: 19 | Quote:
Thanks Brother phone power on by using Alcatel- 708A firmware but after retrieving phone does not show the signal whats going wrong u have any idea please thanks & regards Zafar Janjua | |
05-04-2010, 13:03 | #5 (permalink) | |
708A is for American market (850/1900) and 708X is for 900/1800 | |
05-04-2010, 13:40 | #7 (permalink) | ||
i use 708X fw but phone start blinking when powered on any pet version which can help thanks & regards Zafar Janjua | ||
05-04-2010, 14:04 | #8 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | I Have Not Tested File,But Try This Flash File, Uncheck Fix Security During Flash(if required),Tick In Format FFS During Write, After Repair Security Area After Power ON The Set. 708X-2EVDDE1-17P_XN17BL92_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2010-03-11_En_Cn_Cn.B0M.bin If Problem Is Not Solved Than Use 1 By 1 Br UMER |
05-04-2010, 14:46 | #9 (permalink) |
Member: 71045 Status: Offline Thanks Meter: 19 | every thing should be ok after long time by using this flash file 708X-2CALRU1-16E_XN16BN24_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-08-28_En_Fr_De_Ru_Ua_simfree_v2.B0M.bin check format ffs during write (reset to default value) thanks with all participant Zafar Janjua |
05-04-2010, 16:09 | #10 (permalink) | |
Member: 648590 Status: Offline Thanks Meter: 267 | Quote:
reset backup F:\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_F8CEECD2_E8F450A0_20100504-141544.B0X.bin | |
The Following User Says Thank You to tornado2008 For This Useful Post: |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
