Old 12-25-2009, 10:27   #1 (permalink)
irfan99's Avatar
Member: 242264
Sonork: 100.1582011
Thanks Meter: 33
VODAFONE 541 Unlocking
i have Vodafone 541 and i want to unlock it so i just want to know which phone do i have to select to unlock this model ??? in Infinity Shell there is no model such as alcatel 708 and there is no model in Vodafone such as 541
Old 12-25-2009, 11:47   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
You need to download from support area and install latest "MModule" update.
After you have it installed you will see new supported models in Infinity-Box Shell.
The Following 3 Users Say Thank You to InfinitySupport For This Useful Post:
Old 12-25-2009, 11:51   #3 (permalink)
GSM PAVIA's Avatar
Member: 235881
Thanks Meter: 221
use MM MODULE V 3.0 AND SELECT ALCATEL 708X AND PRSSE SP UNLOCK
Old 12-29-2009, 20:46   #4 (permalink)
Member: 595735
Thanks Meter: 20
I unlocked 4 phones vodafone 541 thank's infinity box
Old 12-30-2009, 14:00   #5 (permalink)
Member: 657023
Thanks Meter: 24
which cable do i use....?
is it the same as orange vegas cable ?
i got mini usb- rj45 cable...but not working
Old 12-30-2009, 17:11   #6 (permalink)
balar's Avatar
Member: 213681
Thanks Meter: 108
http://forum.gsmhosting.com/vbb/show...90&postcount=1
The Following User Says Thank You to balar For This Useful Post:
Old 12-30-2009, 17:34   #7 (permalink)
Member: 572171
Thanks Meter: 23
thnks for infinity we unlock voda phone 541 more 20 phones is working fine just use only rj 45 c701 cable its working
Old 12-30-2009, 20:18   #8 (permalink)
Member: 130995
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
Old 12-31-2009, 13:29   #9 (permalink)
Member: 572171
Thanks Meter: 23
thnks for infinity the best best support for all module best regard for all team member
irfan
Old 01-01-2010, 11:38   #10 (permalink)
Member: 441074
Thanks Meter: 13
COM24 [VCP0] selected
module v2.99
Device: Alcatel-708X, 708A
Checking data, wait...
advanced flash detection enabled voda fone 541 nunlocking succes
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:7003:A001
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98006F00000003:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.40B49 C07.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 40B49C07
rom info protocol ver: 07
ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
ver. sw 2: MAUI.08A.W08.40.SP1.V32, A050F4E8
code offset: 00020000
ffs offset/size: 01800000/00800000
TCL-ID identification
version: 17B
provider: 708X-2EVDDE1
customization: CN17FB75
customization: XN17FB75
TCL-ID identification done
ffs/eeprom address assigned: 01800000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
identification header detected
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 00000000000000
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_40B49C07_E8F450A0_20 100101-160244.B0X.bin
Finished, time used: 348 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following 2 Users Say Thank You to sathi303 For This Useful Post:
Old 01-05-2010, 16:01   #11 (permalink)
amar181's Avatar
Member: 510122
Sonork: 100.1606547
Thanks Meter: 1,822
Arrow
Yes mine another alcatel 541 sucsessfuly unlock .... Thankx for infinity team for hard work....
Here is logs..
COM7 [VCP0] selected
module  v3.00
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:3E03:A00E
status: 01
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.41D49E67.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN_E8F450A0].rpl
TCL-ID detection...
device-id: 41D49E67
rom info ver: 07
sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN
project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8
ffs offset/size [01]: 01800000/00800000
version: 17B
provider: 708X-2HVDGB1
customization: CN17FC75
customization: XN17FC75
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
====>  Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32__system_log_41D49E67_E8F450A0_20100105-070107.B0X.bin
Finished, time used: 3 min 16 sec
Br.
amar181
The Following User Says Thank You to amar181 For This Useful Post:
Old 01-08-2010, 12:19   #12 (permalink)
Member: 289392
Thanks Meter: 3
Yes is true thanks infinity
Old 01-08-2010, 12:29   #13 (permalink)
TEHGSM's Avatar
Member: 109729
Thanks Meter: 36
COM2 [VCP0] selected
module  v3.00
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:4D03:A00A
status: 01
Boot Done
Initialize Done
====>  Set baud ...
115200
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.6EBCC0B7.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN_064A906B].rpl
TCL-ID detection...
device-id: 6EBCC0B7
rom info ver: 07
project-id: MAUI.08A.W08.40.SP1.V32, 6B904A06
version: 17C
provider: 708X-2GVDES1
customization: CN17FE82
customization: XN17FE82
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
====>  Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32__system_log_6EBCC0B7_064A906B_20100108-132521.B0X.bin
Finished, time used: 6 min 9 sec
infinity the best like alaways..
The Following User Says Thank You to TEHGSM For This Useful Post:
Old 01-12-2010, 17:26   #14 (permalink)
Alexandro Monte's Avatar
Member: 846805
Sonork: alex cavalcante
Thanks Meter: 261
COM3 [VCP0] selected
Mَdulo v3.02
Dispositivo: Vodafone-541
Verificando Dados. Aguarde...
Detecçمo Avançada da Flash Habilitada
====> Boot ...
Pressione e SEGURE o Botمo de Ligar!
19200 fixed
Conectando. Aguarde...
Inicializando [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:2E03:A00F
status: 01
Tamanho do Pacote de Inicializaçمo: 0400
Solte o Botمo de Ligar!
Boot Done
====> Inicializar ...
Flash 98006F00000004:09EA0000000000
Flash AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
Nْmero do Chip da Flash/Regiمo Detectada: 01/01
Inicializar Done
====> Determinar Velocidade ...
921600
Determinar Velocidade Done
====> Inicializar Cَdigo de Boot ...
Inicializar Cَdigo de Boot Done
====> Verificar Integridade do Firmware ...
TCL-ID is present
startup code area #1 backup saved: C:\Arquivos de programas\InfinityBox\MModule\backup_security\id.0 D1B0739.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl
TCL-ID detection...
device-id: 0D1B0739
rom info ver: 07
sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
Versمo: 17B
provider: 708X-2EVDIE1
Customizaçمo CN17FH73
Customizaçمo XN17FH73
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
Estado do Travamento do Cartمo SIM: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
Erro: security area (sec info, part #2) header is invalid
Feito
Escrever security area (sec info, part #1)
Escrever security area (sec info, part #2)
Feito
Feito
Verificar Integridade do Firmware Done
====> Verificar Conteْdo do Firmware ...
Verificar Conteْdo do Firmware Done
====> Salvar Cَpia de Dados ...
IMEI Original: 00000000000000
Salvar Cَpia de Dados Done
====> Programar Dados Necessلrios ...
Programar Dados Necessلrios Done
====> Operaçمo Especial ...
Operaçمo Especial Done
====> Escrever ...
Escrever Done
====> Finalizaçمo ...
FFS formatting...
Finalizaçمo Done
Arquivo Salvo: C:\Arquivos de programas\InfinityBox\MModule\backup_security\Voda fone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_0D1B0739_E8F450A0_20100112-141657.B0X.bin
Finalizado. Tempo Gasto: 4 min 3 sec
Remova/Recoloque a Bateria!
The Following User Says Thank You to Alexandro Monte For This Useful Post:
Old 01-15-2010, 09:44   #15 (permalink)
Member: 782390
Sonork: oshiu
Thanks Meter: 57
that is nice solution i have unlocked seven of vodafone 541
with infinity
please help vodafone 541 unlock david69 Infinity-Box 11 07-10-2010 14:04
vodafone 541 unlock problem faisal_sherry Infinity-Box 16 05-30-2010 00:36
Vodafone 541 Unlocked Flash File????........[SOLVED] aslam870 PolarBox 3 5 04-20-2010 21:19
Alcatel 708x / Vodafone 541 Unlocking [ANSWERED] celfat PolarBox 3 8 01-30-2010 16:01
Vodafone 541 unlock? Petyo Easy-Unlocker 16 12-10-2009 16:27
Page generated in 0.28070 seconds with 9 queries
