12-25-2009, 10:27 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Pakistan Peshawar Age: 35
Member: 242264 Status: Offline Sonork: 100.1582011 Thanks Meter: 33 | VODAFONE 541 Unlocking |
12-25-2009, 11:47 | #2 (permalink) | |
You need to download from support area and install latest "MModule" update. After you have it installed you will see new supported models in Infinity-Box Shell. | |
The Following 3 Users Say Thank You to InfinitySupport For This Useful Post: |
12-30-2009, 17:11 | #6 (permalink) | |
No Life Poster Join Date: Dec 2005 Age: 40
Member: 213681 Status: Offline Thanks Meter: 108 | Quote:
The Following User Says Thank You to balar For This Useful Post: |
12-30-2009, 20:18 | #8 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
01-01-2010, 11:38 | #10 (permalink) |
Insane Poster Join Date: Jan 2007
Member: 441074 Status: Offline Thanks Meter: 13 | COM24 [VCP0] selected module v2.99 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled voda fone 541 nunlocking succes Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7003:A001 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.40B49 C07.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 40B49C07 rom info protocol ver: 07 ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN ver. sw 2: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size: 01800000/00800000 TCL-ID identification version: 17B provider: 708X-2EVDDE1 customization: CN17FB75 customization: XN17FB75 TCL-ID identification done ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FB75 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FB75 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000003:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_40B49C07_E8F450A0_20 100101-160244.B0X.bin Finished, time used: 348 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to sathi303 For This Useful Post: |
01-05-2010, 16:01 | #11 (permalink) |
No Life Poster Join Date: May 2007 Location: GSM WORLD
Member: 510122 Status: Offline Sonork: 100.1606547 Thanks Meter: 1,822 | Yes mine another alcatel 541 sucsessfuly unlock .... Thankx for infinity team for hard work.... Here is logs.. Code: COM7 [VCP0] selected module v3.00 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:3E03:A00E status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.41D49E67.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN_E8F450A0].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 41D49E67 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17B provider: 708X-2HVDGB1 customization: CN17FC75 customization: XN17FC75 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FC75 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FC75 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000003:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32__system_log_41D49E67_E8F450A0_20100105-070107.B0X.bin Finished, time used: 3 min 16 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Br. amar181 |
The Following User Says Thank You to amar181 For This Useful Post: |
01-08-2010, 12:29 | #13 (permalink) |
No Life Poster Join Date: Jan 2005 Location: United Kingdom
Member: 109729 Status: Offline Thanks Meter: 36 | Code: COM2 [VCP0] selected module v3.00 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:4D03:A00A status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.6EBCC0B7.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN_064A906B].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 6EBCC0B7 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, 6B904A06 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17C provider: 708X-2GVDES1 customization: CN17FE82 customization: XN17FE82 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FE82 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN17FE82 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00000000000000 flash: 98006F00000003:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32__system_log_6EBCC0B7_064A906B_20100108-132521.B0X.bin Finished, time used: 6 min 9 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to TEHGSM For This Useful Post: |
01-12-2010, 17:26 | #14 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | COM3 [VCP0] selected Mَdulo v3.02 Dispositivo: Vodafone-541 Verificando Dados. Aguarde... Detecçمo Avançada da Flash Habilitada Action: rebuild security area ====> Boot ... Pressione e SEGURE o Botمo de Ligar! 19200 fixed Conectando. Aguarde... Inicializando [6225:8A05:8A00]... CPU: MT6225 chip: 0001:2E03:A00F status: 01 Tamanho do Pacote de Inicializaçمo: 0400 Solte o Botمo de Ligar! Boot Done ====> Inicializar ... detecting chip #00 in region #00... Flash 98006F00000004:09EA0000000000 Flash AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb Nْmero do Chip da Flash/Regiمo Detectada: 01/01 Inicializar Done ====> Determinar Velocidade ... 921600 Determinar Velocidade Done ====> Inicializar Cَdigo de Boot ... Inicializar Cَdigo de Boot Done ====> Verificar Integridade do Firmware ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Arquivos de programas\InfinityBox\MModule\backup_security\id.0 D1B0739.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 0D1B0739 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification Versمo: 17B provider: 708X-2EVDIE1 Customizaçمo CN17FH73 Customizaçمo XN17FH73 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished Estado do Travamento do Cartمo SIM: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished Estado do Travamento do Cartمo SIM: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... Erro: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Feito Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected Customizaçمo XN17FH73 customization name adjusted Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Feito Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected Customizaçمo XN17FH73 customization name adjusted Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Feito Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, part #1) security area (sec info, part #1) calculation done Verificar Integridade do Firmware Done ====> Verificar Conteْdo do Firmware ... Verificar Conteْdo do Firmware Done ====> Salvar Cَpia de Dados ... IMEI Original: 00000000000000 Flash 98006F00000004:09EA0000000000 Salvar Cَpia de Dados Done ====> Programar Dados Necessلrios ... Programar Dados Necessلrios Done ====> Operaçمo Especial ... Operaçمo Especial Done ====> Escrever ... Escrever Done ====> Finalizaçمo ... FFS formatting... Flash 98006F00000004:09EA0000000000 Finalizaçمo Done Arquivo Salvo: C:\Arquivos de programas\InfinityBox\MModule\backup_security\Voda fone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_0D1B0739_E8F450A0_20100112-141657.B0X.bin Finalizado. Tempo Gasto: 4 min 3 sec Remova/Recoloque a Bateria! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to Alexandro Monte For This Useful Post: |
please help vodafone 541 unlock | david69 | Infinity-Box | 11 | 07-10-2010 14:04 |
vodafone 541 unlock problem | faisal_sherry | Infinity-Box | 16 | 05-30-2010 00:36 |
Vodafone 541 Unlocked Flash File????........[SOLVED] | aslam870 | PolarBox 3 | 5 | 04-20-2010 21:19 |
Alcatel 708x / Vodafone 541 Unlocking [ANSWERED] | celfat | PolarBox 3 | 8 | 01-30-2010 16:01 |
Vodafone 541 unlock? | Petyo | Easy-Unlocker | 16 | 12-10-2009 16:27 |
