12-17-2008, 10:18 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | vodafone enter lock code 100% sloved click reset setting problem is sloved phone is working see this log COM6 selected module v1.58 Device: ZTE-225, Vodafone-225 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:22A0 Connecting Done Check hardware ... sw version: -IN-P108A2V1.0.0B06 Sep 24 2007 VDF-P108A2B07-IN05 g3dBV2.0 04.1 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-static_20081217-144128.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-security_20081217-144129.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-complete_20081217-144135.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 27 sec Remove/Install battery now ! |
The Following User Says Thank You to omkarvitekar For This Useful Post: |
12-17-2008, 19:12 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. | |
B100i tracker code 100% sloved | omkarvitekar | UST Pro II | 0 | 12-07-2009 14:50 |
KG270 cannot enter lock codes need help.. | kungpaoski | FuriousGold | 4 | 12-30-2007 05:50 |
z300a entering lock code? | slaherx | Cruiser Suite | 5 | 07-14-2007 19:14 |
9210 problem entering lock code | dominik | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-13-2003 13:00 |
MT¦140¦astral¦Enter¦Lock¦Code | spidergsm | Mitsubishi | 1 | 12-04-2002 01:39 |
