Vodafone smart tab iii 7 mt6589 problem... VODAFONE SMART TAB III 7 MT6589__LENOVO__Vodafone_Smart_Tab_III_7__IdeaTabA 3000-H__A3000__ALPS.JB2.MP.V1.9__Android_4.2.2__2013081 3_211911 Tablet was asking for privacy lock, tryed to remove withou sucess, so i 1-back up flash 2-format with safe mode without sucess 3-format with *0* ok 4-phone stuck on logo and ask for *DL MODE* but when i try to fix cant fix 5- try to flash with back up, always same error; Chinese Miracle II [MTK module] v 1.13 Load File File_Info : lenovo89_tb_vf_a_jb2 FileVersion : MT6589 Load File Ok Operation : Flash [ v1.13 ] ======= Flash Files set for flashing : [ MCU ] : VODAFONE SMART TAB III 7 MT6589__LENOVO__Vodafone_Smart_Tab_III_7__IdeaTabA 3000-H__A3000__ALPS.JB2.MP.V1.9__Android_4.2.2__2013081 3_211911.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 484A019065324741A20102045F80D660 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : e2GA [eMMC] : FLASH_CID : 90014A4841473265040201A260D6805F [eMMC] : FLASH_LEN : 0x00000003AB800000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ISPFF ID : 6589 TARGET ID : 6583 Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : VODAFONE SMART TAB III 7 MT6589__LENOVO__Vodafone_Smart_Tab_III_7__IdeaTabA 3000-H__A3000__ALPS.JB2.MP.V1.9__Android_4.2.2__2013081 3_211911.ispff Init Ok , Sending blocks ... Write failed :( Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:01:53 Reconnect Power/Cable! the phone doesnt have usb conection either battery problem, need help:confused: br Macie@Provider |
Hi. I want see to "Remove Privacy" and "Fix DL" logs. Very interest. |
1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 484A019065324741A20102045F80D660 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : e2GA [eMMC] : FLASH_CID : 90014A4841473265040201A260D6805F [eMMC] : FLASH_LEN : 0x00000003AB800000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Privacy Lock not set! Done! Elapsed: 00:00:12 Reconnect Power/Cable! and Operation : Fix DL Errors [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 484A019065324741A20102045F80D660 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : e2GA [eMMC] : FLASH_CID : 90014A4841473265040201A260D6805F [eMMC] : FLASH_LEN : 0x00000003AB800000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
@Macie provider , this phone have privacy lock enabled? I need to check the dump, but 16GiB is very big size. Will send you instructions and some things to make some tests after few hours in PM. |
Its not phone lock, becouse phone was working fine without sim and its not network locked im sure, i already tryed to format manually with adb etc...didnt work. so my conclusion *privacy lock* info: when i try to flash with *FLASH ERASE* checked stop on 1% unchecked 3% br Macie@Provider |
Hope, you charged battery fully :D Just tested 2x 6589 samples to make sure about all is working Okay. Privacy Lock - should ask for Privacy Password. If it is not Privacy ( because not seen yet it on 6589 ) - that can mean some problrems with flash IC , but anyway, need check all before. |
UP UP, can i have at last any flasher to flash using my backup to put the phone in the way was before?:confused::confused: |
most probably battery is not full charge use external supply for battery charge and charge battery atleast 1 or 2 hours than try to flash one more thing when battery charge it cant coneect wth tablet |
Then, you not make any factory FW backup before? |
didnt acepted to make when tryed to, only this full backup, my question: is there any one with this factory FW backup ?:confused: |
Dear JayDi Still nothing from you? br Macie@Provider |
@jaydi can you activate my infinity dongle ?so I can make test and upload logs for latest phones? check you PM did sent 2 times request for my infinity dongle s/n thanks |
no need to PM no body, read...http://forum.gsmhosting.com/vbb/f296...iatek-1827134/ |
@jaydi told me to activate free my infinity dongle for latest mtk /spd phone software) for infinity that's is why I send him pm |
