Old 09-23-2016, 08:16   #1 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Unhappy Vodafone Smart_mini7 VFD300 Stuck
Hello ,
The cellphone came for frp reset so i did full factory reset after all its stuck on startup ( A rounding ball ) is appearing since after. Please help Sir.
Here is the operations log :
Read Info Log :
Chinese Miracle II  [MTK module] v 1.56
Start  at : [9/22/2016 / 5:20:52 PM]
Operation : Check / Read Info [ v1.56 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 11010030303447453000DA53B37A3373
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 0EG40
[eMMC] : FLASH_CID : 11010030303447453000DA53B37A3373
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID    : 0x47F50D0AEA244D9DF3E1AC406360630E
INT RAM    : 0x00020000
EXT RAM    : 0x20000000 [512 MiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : Vodafone
ProdName  : Smart_mini7
ProdModel : VFD 300
Device    : VFD300
AndroidVer: 6.0
MTKxCPU   : MT6580
MTKxPRJ   : alps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P38
SECURITY :
IMEI_OTP [1] : 356774072656309
EXTRA :
LCD : Not info available :(
LCD Res : 800x480
TOUCH [0] : GT1XX
CAM [0] : ov5670_mipi_raw
CAM [1] : s5k5e8yx_mipi_raw
CAM [2] : ov2680_mipi_raw
CAM [3] : gc2355_mipi_raw_rear
CAM [4] : gc2355_mipi_raw_front
CAM [5] : sp2508_mipi_raw
CAM [6] : gc0310_mipi_yuv
MODEM : jhz6580_we_vf_m_hspa jhz6580_we_vf_m_gprs
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.56 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:01:26
Finish at : [9/22/2016 / 5:26:17 PM]
Old 09-23-2016, 08:58   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Did you made Backup?
Reinstall battery (take out and insert battery again), switch ON phone and wait for 2-3 minutes, sometimes this works.
Alternatively you can do Repair ExtData and check again.
Br.
Infinity Box Support Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 09-23-2016, 09:06   #3 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Unhappy
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
Hello,Thanks for your reply.
Let me explain i have done alot. I've got backup (full firmware backup)
I had try to write back that firmware still same, I did try also ExtData , I did full factory reset more than 3 time before write back and after, I remove battery many times and put it back still same.
Some logs are here again.
Start  at : [9/22/2016 / 5:21:10 PM]
Operation : Read Flash [ v1.56 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
xGPT : Normalize settings Ok!
Brand     : Vodafone
ProdModel : VFD 300
Device    : VFD300
AndroidVer: 6.0
MTKxCPU   : MT6580
[Read Ok] : preloader_samg_vf.bin
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : logo.bin
[Read Ok] : secro.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6580 / V1.1.2 / samg_vf / EMMC
Android Info saved
HWConfig Info saved
FW Size : 615 MiB
Scatter saved to : C:\Users\Shakeel Software\Desktop\MT6580__Vodafone__VFD_300__VFD300__6.0__alps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P38\
All done!
Done!
Elapsed: 00:03:31
Scatter Load Ok , BaseBand : MT6580 , Project : samg_vf , Storage : EMMC
Files found : 9 , Set to Flash : 8
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand   : Vodafone
Device Model   : VFD300
Device CPU     : MT6580
Device IntName : Smart_mini7
Device Version : 6.0
Device Compile : 5/26/2016 3:32:11 AM
Device Project : alps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P38
Device ExtInfo : VFD 300
Ready to Flash!
Start  at : [9/22/2016 / 5:55:18 PM]
Operation : Flash [ v1.56 ]
======= Flash
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6580 , Project : samg_vf , Storage : EMMC
Setting : AFF verify :  Enabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3839 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 3
Erase : 0x0000000001C80000-0x0000000003320000
Erase : 0x00000000050A0000-0x0000000005760000
Erase : 0x000000000B000000-0x00000000DD480000
Flash Pre-Erase Done, time used : 00:00:00
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_samg_vf.bin
Preloader Sent , Init passed
PartCount : 0016
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:02:04
Processing : Verify
Verify Passed : LK
Verify Passed : BOOT
Verify Passed : RECOVERY
Verify Passed : LOGO
Verify Passed : SECRO
Verify Passed : SYSTEM
Verify Passed : CACHE
Verify Passed : USERDATA
Data Verify Done, time used : 00:00:03
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:02:21
Finish at : [9/22/2016 / 5:57:38 PM]
File Type: jpg 14438974_10206996994500096_505011981_o (1).jpg (341.7 KB, 111 views)
Old 09-23-2016, 11:30   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
It MT6580.
It can stuk up to 20-25 minutes before first start!
Also, alternate way - select second WIPE mode and do format.
Run phone and leave it until it boot completely.
The Following User Says Thank You to JayDi For This Useful Post:
Old 09-23-2016, 13:43   #5 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Unhappy
Originally Posted by JayDi View Post
It MT6580.
Hello, Thanks for your reply. I even did yesterday same as you say!
Now i am done again . its been 1 hour now and the phone is stuck still.
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand     : Vodafone
ProdModel : VFD 300
Device    : VFD300
AndroidVer: 6.0
MTKxCPU   : MT6580
SECURITY :
EXTRA :
LCD Res : 800x480
TOUCH [0] : GT1XX
Done!
Elapsed: 00:00:31
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear RDP
Clear Ok!
Done!
Elapsed: 00:00:15
Old 09-23-2016, 14:00   #6 (permalink)
Member: 2082450
Thanks Meter: 1,454
Arrow
@Shakeel_pattoki,
Hello, as per Mr Passionate boys question,
You have made backup before format or after format operation????
I think there is some problem in mobile firmware.
So search working firmware and re-flash it again.
Also, Post here HW Test report..
Old 09-23-2016, 14:04   #7 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Originally Posted by chandanps18 View Post
@Shakeel_pattoki,
Hello , Thanks for your attention, Kindly please see my operation logs and first post . As i said there was no problem, just want to remove FRP .
Br.
Old 09-23-2016, 14:08   #8 (permalink)
Member: 2082450
Thanks Meter: 1,454
Arrow
Br.
Hello,
Please do as I said.
It helps sometimes.
Thank you...
Old 09-23-2016, 14:14   #9 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Hello,
It helps sometimes.
Thank you...
I already write back the backup , that i have read before format. What should i do more ?
Old 09-23-2016, 14:29   #10 (permalink)
Member: 2082450
Thanks Meter: 1,454
Dear sir,
As I told you before and as per your report,
as the backup is not working.
Please try search this firmware with same ver and flash it...
also post here hw test reports.
The Following User Says Thank You to chandanps18 For This Useful Post:
Old 09-23-2016, 14:31   #11 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Dear sir,
Hello, Dear Sir , if i was having another fone its was going to be done early in the morning. I don't have another phone right now. Thanks for your kind support.
I didn't even find fresh firmware over the Google .
Br.
Old 09-23-2016, 14:39   #12 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
HW test report
Operation : HW Test [ v1.56 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Processing Miscellaneous test
MSC : BatteryLevel : 3717 mV
[Processing] FlashMemory Read-Write test
[eMMC] : [TOSHIBA] , 0EG40 , 0xEC000000 , 3776 MiB
[eMMC] : CID : 11010030303447453000DA53B37A3373
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
[Processing] RAM Read-Write test
[DRAM] : 0x20000000 , 512 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x1C
[DRAM] : DATA BUS test
[PASSED] : Bus Count : 0x1F
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
Elapsed: 00:01:38
Old 09-23-2016, 15:43   #13 (permalink)
JayDi's Avatar
Member: 462970
Post here scatter file from that FW. Just scatter file.
Old 09-23-2016, 15:48   #14 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
I have found another working cellphone in my hands. I have another read file from it. I had done flashing to the old patient still not working.
Here i am attaching scatter file, Please download it.
Br.
Old 09-23-2016, 18:24   #15 (permalink)
JayDi's Avatar
Member: 462970
I had checked and didn't found anything strange in it.
Simple Alcatel-like.
Request - make Flash dump from this faulty device. For emergency case.
Select Alcatel. Go to extra tab - alcatel. Do Repair MInfo.
Page generated in 0.40705 seconds with 9 queries
