11-30-2007, 02:41 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: peru Age: 57
Member: 215758 Status: Offline Thanks Meter: 33 | zte a12+ sp-unlock this yano you that to make the client above helps derrepente makes bad or that lacks to make it the cel also works well I place him the clearing sim it works but I want for movistar COM12 [VCP0] selected Device: ZTE-A12+ Checking data, wait... Action: unlock Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: EC22A000000000:38E59F00000000 flash: Samsung T 4Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... Check flash Done Check space... file saved: C:\Archivos de programa\InfinityBox\AModule\backup__eeprom-calibration_20071129-202048.98E.bin warning: wrong data size at 0x01370800, retry... read error recovered warning: wrong data size at 0x0137E000, retry... read error recovered warning: wrong data size at 0x0137E800, retry... warning: wrong data size at 0x0137E800, retry... warning: wrong data size at 0x0137E800, retry... warning: wrong data size at 0x0137E800, retry... warning: wrong data size at 0x0137E800, retry... warning: wrong data size at 0x0137E800, retry... warning: wrong data size at 0x0137E800, retry... warning: wrong data size at 0x0137E800, retry... warning: wrong data size at 0x0137E800, retry... error: too many retries during read operation file saved: C:\Archivos de programa\InfinityBox\AModule\backup__eeprom-ffs_20071129-202137.98E.bin Reading[lock-area-2]... warning: wrong data size at 0x011F0000, retry... warning: wrong cs at 0x011F0000, retry... warning: wrong data size at 0x011F0000, retry... warning: wrong cs at 0x011F0000, retry... warning: wrong data size at 0x011F0000, retry... warning: wrong data size at 0x011F0000, retry... warning: wrong data size at 0x011F0000, retry... warning: wrong data size at 0x011F0000, retry... warning: wrong data size at 0x011F0000, retry... error: too many retries during read operation error: can't read flash area, operation aborted Check space Fail error: no any expected answer Finished, time used: 89 sec Remove/Install battery now ! |
11-30-2007, 07:03 | #3 (permalink) |
Member: 215758 Status: Offline Thanks Meter: 33 | not never COM12 [VCP0] selected Device: ZTE-A12+ Checking data, wait... advanced flash detection active Action: unlock Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: EC22A000000000:38E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... Check flash Done Check space... file saved: C:\Archivos de programa\InfinityBox\AModule\backup__eeprom-calibration_20071129-234257.98E.bin warning: wrong data size at 0x01370800, retry... read error recovered warning: wrong data size at 0x0137C400, retry... warning: wrong data size at 0x0137C400, retry... warning: wrong data size at 0x0137C400, retry... warning: wrong data size at 0x0137C400, retry... warning: wrong data size at 0x0137C400, retry... warning: wrong data size at 0x0137C400, retry... warning: wrong data size at 0x0137C400, retry... warning: wrong cs at 0x0137C400, retry... error: unexpected data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warning: wrong cs at 0x0137C400, retry... error: too many retries during read operation file saved: C:\Archivos de programa\InfinityBox\AModule\backup__eeprom-ffs_20071129-234337.98E.bin Reading[lock-area-2]... error: wrong answer[97] error: can't read flash area, operation aborted Check space Fail error: wrong answer[3B] Finished, time used: 57 sec Remove/Install battery now ! |
11-30-2007, 13:24 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, double check cable, be sure that phone connector contacts is cleran, that your cable is quite short and that battery enough charged. As I can see from your logs the problem is a communication error that can be a result of cabler problems. Each time error at different address, this means that it's not software problem but it's cable problem or phone hardware problem. |
12-01-2007, 05:24 | #5 (permalink) |
Member: 215758 Status: Offline Thanks Meter: 33 | already revise step for step the cable he/she has 10 centimeters the connector ok I proved it now with another celeluar and the same thing I request a solution to my problem departe of the support of this box |
ZTE A12+ succesfully unlock by infinity. | sayfulalam | Infinity-Box | 9 | 08-29-2009 08:27 |
23 Jun 2008: ZTE-A12, A12+, A15, A16, A37, A39, A80, 2010, WP626, Coral-300 imei... | InfinitySupport | Infinity-Box | 29 | 07-08-2008 07:24 |
22 Jun 2008: "AModule" v1.30:imei repair function added for .ZTE-A12, A12+, A15, A16, | alamgir80 | Infinity-Box | 6 | 06-23-2008 11:48 |
23 Jun 2008: ZTE-A12, A12+, A15, A16, A37, A39, A80, 2010, WP626, Coral-300 imei... | SHANU | Service Products News & Updates | 0 | 06-23-2008 09:59 |
ZTE A12+ Unlock problem | himu_mm | Infinity-Box | 3 | 03-17-2008 12:09 |
