02-29-2020, 07:34 | #1 (permalink) |
Junior Member Join Date: Jun 2017 Location: Sudan
Member: 2728849 Status: Offline Thanks Meter: 0 | help Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000D00E18434082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 483CD00E Firmware version: 0137.02 === Process started: 2/26/2020 7:06:56 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to infinity |
02-29-2020, 09:45 | #2 (permalink) | |
Why do you use debugger and other crack tools with Infinity software ? | |
03-02-2020, 10:04 | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Code: PowerISO is a powerful CD / DVD / BD image file processing tool, which allows you to open, extract, burn, create, edit, compress, encrypt, split and convert ISO files, and mount ISO files with internal virtual drive Another try ? |
03-02-2020, 10:40 | #12 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | try to update dongle firmware now. If you are lucky it will be fixed. in any case I suggest you never use any kind of strange tools and strange registration methods with cracks, this may damage dongle permanently. |
03-02-2020, 10:56 | #13 (permalink) | |
Member: 2728849 Status: Offline Thanks Meter: 0 | Quote:
It is works Sent from my RNE-L21 using Tapatalk | |
