02-01-2009, 18:15 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Vodafone_zte_125_successfully_unlocked HERE IS THE LOGS SET_NO_1 ---------- COM14 [VCP0] selected module v1.60 Device: ZTE-125 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: -DE-P108A1V1.0.0B02 VDF-P108A1B07-De-DE03 g3dBV2.0 16 59 13 04.1 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20090201-180837.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20090201-180837.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20090201-180839.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_lock-area_20090201-180843.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 44 sec Remove/Install battery now ! SET_NO_2 ---------- COM14 [VCP0] selected module v1.60 Device: ZTE-125 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: -DE-P108A1V1.0.0B02 VDF-P108A1B07-De-DE03 g3dBV2.0 16 59 13 04.1 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20090201-181137.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20090201-181138.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20090201-181139.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_lock-area_20090201-181143.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 25 sec Remove/Install battery now ! |
The Following User Says Thank You to mobile_hotman For This Useful Post: |
02-01-2009, 22:46 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
