Voice V10i Flah File Need Voice V10i Flash File Download From Voice Support But Gives Error In Flashing Anyone Have Bin Or Factory File Read By Cm2 Please Share Thanks In Advance |
Please If Any One Have File Post Here Badly Need |
Need Voice V10i Flash File |
Download Link :-Voice V10i |
thanks br |
flash this firmware with SP Flash Tool post result/logs..... |
tested file 100000000000 ok se v10i MT6571__NAND__v13_GSM ROOFI |
Chinese Miracle II [MTK module] v 1.41 Operation : Check / Read Info [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 8FDB1A5E3BFCCD6B6C68811AC67742FC INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : v13_n4gb2gb_2ggsm4_hvga_v1bom_hl_voice ProdModel : Xtreme V10i Device : v13_n4gb2gb_2ggsm4_hvga_v1bom_hl_voice AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.KK1.MP7.V1 Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
Thanxs Mr Syed Toqeer your file 100% ok working fine i flash with SP Flash tool |
Supper File 4.4..2 Quote:
