04-08-2015, 10:00
#1 (permalink)
Member: 199814
Thanks Meter: 1,960 | Voice V40 hang on logo Flash logs please help me what to do Quote:
Card found: S/N 4389:0128
Chinese Miracle II [MTK module] v 1.16
Scatter Load Ok , BaseBand : MT6572 , Project : mtk_android , Storage : EMMC
Files found : 16 , Set to Flash : 15
Ready to Flash!
Operation : Flash [ v1.16 ]
======= Flash
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 7001004D4D43303447020609738E7059
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0070 , OEM : 0100
[eMMC] : FLASH_INF : G40CM
[eMMC] : FLASH_CID : 7001004D4D43303447020609738E7059
[eMMC] : FLASH_LEN : 0x00000000E2C00000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : mtk_android , Storage : EMMC
Setting : AFF verify : Enabled
SecCfg Passed , 1799
BL : Check HW compatibility
BL : Check eMMC compatibility
BMT remark not need. Will skip
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000000A00000-0x00000000E1120000
Flash Pre-Erase Done, time used : 00:00:08
BL : Clear old BL Data
BL : Clear old BL Data Ok
Sending Preloader ...
Use : preloader.bin
Preloader Init Failed! Looks like HW error or incompatible image
Done!
Elapsed: 00:00:30
Reconnect Power/Cable! | |
