04-05-2018, 16:56 | #1 (permalink) |
Insane Poster Join Date: Apr 2011 Location: Romania
Member: 1555576 Status: Offline Thanks Meter: 11 | Vonino Xylo P SC7731C FRP error I want to reset FRP on Vonino Xylo P SC7731C Code: Start at : [05.04.2018 / 18:27:05] Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 43 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Finish at : [05.04.2018 / 18:27:14] Code: Start at : [05.04.2018 / 18:27:28] Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 43 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Init Ok , reset settings ... Format Ok! Done |
04-06-2018, 04:57 | #2 (permalink) | |
Freak Poster Join Date: Jan 2017
Member: 2671513 Status: Offline Thanks Meter: 121 | Quote:
use latest version 1.27 | |
The Following User Says Thank You to dadarko For This Useful Post: |
04-06-2018, 08:45 | #3 (permalink) |
Member: 1555576 Status: Offline Thanks Meter: 11 | yes, my mistake... Code: Set mode to : SP [SC773x] eMMC [Android 7.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 43 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC Loader v7 InfinityBox Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000002CC0F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:23 |
01-31-2019, 10:49 | #4 (permalink) |
Junior Member Join Date: Feb 2015 Location: Romania Age: 35
Member: 2348708 Status: Offline Sonork: 100.1673254 Thanks Meter: 0 | Card found: S/N : ED1C57D9 , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP SC77xx [Model Select] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 74 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Boot Files missing! Select SLDR or PAC file! Boot failed! Reconnect Power/Cable! |
