W220 dead. Please help me Support Team!!!! Hi, I was trying to unlock a Motorola W220 locked to TUYO Provider. Here is first log: COM5 [VCP0] selected module v1.34 Device: Motorola-W220 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb software version: 235C-000 software version: SCU-9- Check hardware done Read data ... reading Motorola-W220_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Motorola-W220_eeprom_calibration-1_20091219-133048.6AE.bin Read data done Check data ... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user error: not locked or unknown eeprom Check data done Write ... .error: required data not found or unknown eeprom structure Write fail error: operation failed Finished, time used: 14 sec Remove/Install battery now ! I read in the forum that I needed to flash with a repair eeprom so I did, I flashed with this eeprom: W220_repair_eeprom_10.6AE.bin, here is operation log: COM5 [VCP0] selected module v1.34 Device: Motorola-W220 "advanced chip detection" active Action: flash write Skip: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Write: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb software version: 235C-000 software version: SCU-9- Check hardware done Read data ... Read data done Check data ... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user Check data done Write ... Area: Eeprom flash: 208810FFFFFFFF:20881000000000 Write: Eeprom Write done Finished, time used: 25 sec Remove/Install battery now ! Everything went smoothly, but now phone wont power on, It wont boot, It wont connect to the sofware. I charged the battery full with another phone, tried with different cables, tried with other boxes but it just won't work. Phone was fully functional before I flashed with eeprom so it is not hardware problem. Please help me. |
Try to flash with full flash ..not only eeprom |
The phone won't connect to the software, after I flashed with that eeprom, phone is not responding. |
try to use RPS than battery................. |
Try to use something what match with 235C and format ffs. |
Where is support team anyways??? |
It can not be true that after flashing phone with repair eeprom phone can not boot any more. At least I do not have any kind of this examples. You need to double check your cable, check all wires carefully. Try to use another cable. After you will be able to boot phone you just need to make "Repair" operation. |
got same prob here my friend...i have w220 already unlocked...i just need to flash it to work with 900/1800mhz....i notice this error: warning: Probably wrong model selected, Do you want to continue ? i just press yes...and flashing went smooth...after flashing, the phone was dead...i thought wrong flashfile..but when i reflash it again, THE PHONE WON'T CONNECT ANYMORE....i did everything i can..use other t191 cable, even direct to its pinout, etc.... infinity team, please try this prob, i hope you can figure it all out... thanks |
relax......... hehehehehe dis assymble the unit! flash it with mother board only! Quote:
hehehehehehe demanding?lol! unlocking seems smothly but after unlock it seems dead? isnt the user is wrong or not doing the right procedure? |
men, we have the same situation....maybe infinity team may think that it is imposible.....but i am looking forward for them to solve this.....w220 S/W:S2.35B |
I flashed hundreds of W220... no Mobile died on Flashing... Are you even sure you can change Freuqencies on Flashing a different EEProm? In any case it should still boot... try to play with cable... sometimes you have to cut an mm... Phones with T191 have alot of CableProblems... so recheck... @arx: Infinity can`t help you... if a phone is not responsing (that can`t be on a w220) NO ONE can help you. What should an Update do with the phone if it would be dead... funny guys... doing b**l**** on phones and asking for Updates... funny... |
THANKS |
