Old 08-07-2008, 23:51   #1 (permalink)
moustafatch's Avatar
Member: 21750
Sonork: 100.62509
Thanks Meter: 73
w220 - w375 can't connect
i have w220 and w375
i can't connect by any way
i try com cable and usb even pin finder
and some thing strange when i try user code and phone should to be on connected and phone code 0000
both phones is brand new cable and phone soket clean and already opened the phone and rechek the soket
what wrong code be ?
Old 08-08-2008, 15:54   #2 (permalink)
Member: 21750
Sonork: 100.62509
Thanks Meter: 73
any answer from infinty team ?
Old 08-09-2008, 14:47   #3 (permalink)
Member: 21750
Sonork: 100.62509
Thanks Meter: 73
i am very wonder why no such answer
maybe coz my post don't give chanse to say clean the soket. chek cable. change pc ?
Old 08-09-2008, 14:58   #4 (permalink)
Member: 128745
Thanks Meter: 16,936
reduce the baud rate and try again
Old 08-09-2008, 14:59   #5 (permalink)
Member: 21750
Sonork: 100.62509
Thanks Meter: 73
already try all avalible baudrate and all connaction method
i have noticed that w220 phone code working while phone is on
Old 01-18-2009, 08:30   #6 (permalink)
Member: 767451
Thanks Meter: 178
and me i have problem like this in w 375 pls help any user cant boot for any cables pls sir
Old 01-18-2009, 15:29   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
@fidmdoe
What is the problem exactly with w375 connection ?
Old 01-22-2009, 07:48   #8 (permalink)
Member: 767451
Thanks Meter: 178
i tr y many times to unlock this pc with x60 cable but can,t boot pls help sir. and what about w 230/ w181 /150i pls help
Old 01-22-2009, 14:26   #9 (permalink)
Member: 130995
Hello,
Please, post here operation log so we will be able to check what is wrong.
Old 01-30-2009, 00:02   #10 (permalink)
fretburner's Avatar
Member: 45571
Thanks Meter: 45
W220 flashed using infinity and have warning software not same as from unit but i still flashed it and now dead and not connecting.Any tips how to revive this unit?
Old 01-30-2009, 00:27   #11 (permalink)
fretburner's Avatar
Member: 45571
Thanks Meter: 45
COM1 [Serial2] selected
module v1.30
Device: Motorola-W220
"advanced chip detection" active
Action: flash write
"smart write" active
Write: Firmware
Skip: Flex
Skip: Language Pack
Skip: FFS/File system
Skip: Images
Skip: Melody
Skip: Eeprom
Checking data, wait...
Boot ...
Press Power button now !
loading...
Boot done
Check connection ...
Check connection done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 208810FFFFFFFF:20881000000000
flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb
software version: 235C-000
software version: SCU-9-
Check hardware done
Read data ...
reading Motorola-W220_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Motorola-W220_eeprom_calibration-1_20090129-204345.6AE.bin
reading Motorola-W220_ffs...
file saved: C:\Program Files\InfinityBox\HModule\Motorola-W220_ffs_20090129-204543.6AE.bin
Read data done
Check data ...
warning: Probably wrong model selected,
Do you want to continue ?
model selection confirmed by user
Check data done
Write ...
Area: Firmware
Write: Firmware
Write done
Finished, time used: 640 sec
Remove/Install battery now !
Old 01-30-2009, 02:56   #12 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
bad news for you I don't know if you are from Nicaragua and that phones are from claro let me tell you what problem is claro or personal in south America is the famous tracfone now this companies are using k3 firmware that allow you to connect the phones to any box
Old 01-30-2009, 05:28   #13 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
My bad k3 soft don't let phone connect to any box
Old 01-30-2009, 09:52   #14 (permalink)
Member: 130995
@fretburner
Phone can not be dead permanently after flashing with files from support area.
Charge battery and try to flash phone again with more high version files set (main + lp + images + melody + flex).
@denisirias
I don't think that phone can not be connected due to wrong firmware,
It may be that phone can not power-on but phone should have ability to be flashed.
Old 01-31-2009, 00:59   #15 (permalink)
denisirias's Avatar
Member: 309299
Thanks Meter: 259
Originally Posted by InfinitySupport View Post
@fretburner
@denisirias
well phone cannot be flashed it is the same case as some v170 from tracfone, and some w376g from tracfone or some c122 from movistar that infinity cannot athach
can't connect w220 market.killer Infinity-Box 7 06-18-2008 16:10
Motorola W220, SWVer=1.370 can't connect, unlock serjer Smart-Clip 2 05-06-2008 12:25
W375 wont connect to PC? CharlyAR Motorola ODM 6 11-19-2007 13:54
@GSM_Support - SmartClip will be support W220, W375 & etc? fingusio Smart-Clip 5 02-19-2007 21:22
Page generated in 0.20261 seconds with 9 queries
