01-31-2009, 09:23 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Buy Buy Thank U GsmHostig .... Age: 41
Member: 462292 Status: Offline Thanks Meter: 397 | **** kg280 unlock done **** COM7 [VCP0] selected module v1.36 Device: LG-KG280 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 355222010173855 current otp imei: 355222010173855 file saved: C:\Program Files\InfinityBox\LGA\eeprom_355222010173855_LG-KG280_20090131-134813.B1E.bin .... Check flash Done Check space ... current eeprom imei: 355222010173855 ................................... finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 44 sec Remove/Install battery now ! ok |
The Following User Says Thank You to kalpeshoza For This Useful Post: |
thanks to setool team T715 cid53 unlock done few second free | kadricom | SETool2 | 6 | 02-16-2011 10:38 |
LG-KH1800 SHOW (KOREAN PHONE) UNLOCKED DONE AGAIN! PIC'S and PROCEDURE INSIDE | Ligalig | LG | 1 | 03-30-2010 07:40 |
S 5600 unlock done | maxtele | Z3X-Team Products | 0 | 03-29-2010 13:22 |
9530 verizon blackberry unlocking done with mx | rajesh_ch | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 0 | 03-29-2010 11:57 |
