Old 01-30-2009, 13:30   #1 (permalink)
Registered User
Member: 76882
Thanks Meter: 56
Z300 flash file
hello
z300 dead , read flash files is emty please check logs and tell me is it hardware or software probem?
COM6 [VCP0] selected
module v2.73
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection disabled
Action: read NOR flash
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:73C1A56
high speed boot Off
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: 89881600010001:89881600000000
flash: Intel B 32Mb
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
flash: Intel B 32Mb
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
total flash region size: 02000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 01000000
checking area [00000000]: 00000000-01FFFFFF...
eeprom/ffs found near: 01600000
Detected eeprom/ffs address is non-standard: 01600000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address confirmed by user: 01600000
detecting eeprom/ffs size...
eeprom/ffs size: 00A00000
ffs chip: 00
eeprom/ffs area: 00000000:01600000-01FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: flash...
Old 01-30-2009, 20:36   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Post here phone photo, probably somebody can give you an information what firmware should be used.
Also you can check PCB, fins marks at PCB and try to find similar firmware in support area.
Old 01-31-2009, 07:45   #3 (permalink)
Registered User
Member: 76882
Thanks Meter: 56
thanks i'll try and tell u result
z300 flash files noi Cruiser Suite 8 02-21-2009 13:52
z300 flash file for hwk need kasra HWK 2 09-17-2006 23:01
need K600 & Z300 flashe file cooloxf SonyEricsson (USB-Smart) 4 08-27-2006 11:05
SE Z300 flash file needed.. mobilesmith Cruiser Suite 7 07-06-2006 07:37
Z300 flash files needed... Invader Cruiser Suite 1 05-22-2006 10:26
Page generated in 0.15524 seconds with 9 queries
