01-23-2018, 07:31 | #1 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | cm2 support software and drivers download link problem please sir solve this problem |
01-23-2018, 07:35 | #3 (permalink) | |
No Life Poster Join Date: Oct 2013 Location: MajeedGsm
Member: 2046498 Status: Offline Sonork: 100.1676751 Thanks Meter: 162 | download it from from given Quote:
link here... Index of pub//software/ | |
01-23-2018, 08:40 | #5 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Hello, Official download area via IOS How-to-HERE http://forum.gsmhosting.com/vbb/12355828-post1.html Login here https://user.infinity-box.com/ |
The Following 2 Users Say Thank You to Kirumira For This Useful Post: |
01-23-2018, 18:05 | #6 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
10-30-2018, 07:55 | #7 (permalink) |
Freak Poster Join Date: Jun 2013 Location: south Africa
Member: 1960717 Status: Offline Sonork: 100.1638403 Thanks Meter: 34 | Card found : S/N : B7C2118A , v0135 Chinese Miracle II [MTK module] v 1.56 Operation : Format FileSystem [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 60 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! SECURE BOOT Mode Enabled! Try select NORMAL SP Mode! Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Format FileSystem [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 60 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Format FileSystem [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 59 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! SECURE BOOT Mode Enabled! Try select NORMAL SP Mode! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
