Old 07-16-2008, 23:34   #1 (permalink)
Member: 66841
Question LG KG290 resets after flesh
Release Power button !
flash: 89881600010001:89881600000000
flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb
Boot Done
Set baud...
460800
Set baud Done
Check flash...
current eeprom imei: 35745*********x
file saved: C:\Program Files\InfinityBox\LGA\eeprom_3574*********x_LG-KG290_20080716-235653.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
Write: Firmware (code)
Write: Alchemy data
Write: Eeprom
flash: 89881600000000:89881600000000
Write Done
Finished, time used: 85049 sec
Remove/Install battery now !
I flash phone to change the language after the surgery to reset and is still only a logo KG290.
How can I fix this?
I have a new version 1.31 LGA
Old 07-18-2008, 11:02   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What files you have used for flashing ?
Old 07-18-2008, 11:30   #3 (permalink)
Member: 224810
Thanks Meter: 15
same problem
i use these files
KG290P40-07-V10b-***-XX_OCT-22-2007-CodeData_w_calibration[1].B1M.bin
KG290P40-07-V10b-***-XX_OCT-22-2007_AlchemyData[1].B1P.bin
i flashed with InfinityUpdate_LgA_v1[1].29.rar software
Old 07-18-2008, 11:41   #4 (permalink)
Member: 130995
Did you tried to use another flash files set ?
What is exact text from phone back label ?
Old 07-18-2008, 12:05   #5 (permalink)
Member: 224810
Thanks Meter: 15
i tried KG290P40-ARB-V10b-***-XX_SEP-10-2007_AlchemyData[1].B1P.bin
KG290P40-ARB-V10b-***-XX_SEP-10-2007_CodeData[1].B1M.bin
also
and after full flash there is
wrong pacage message
Old 07-18-2008, 13:01   #6 (permalink)
Member: 224810
Thanks Meter: 15
Check flash Done
Check space...
Check space Done
Check parameters...
Erase...
Erase Done
Write...
Write: Eeprom
Write Done
error: wrong answer: C5
Finished, time used: 29 sec
Old 07-18-2008, 22:13   #7 (permalink)
Member: 130995
also
What is \"wrong pacage\" ?
Where you can see it ?
Old 07-19-2008, 09:00   #8 (permalink)
Member: 66841
i use these files
KG290P40-07-V10b-***-XX_OCT-22-2007-CodeData_w_calibration.B1M
KG290P40-07-V10b-***-XX_OCT-22-2007_AlchemyData.B1P
and
KG290P40-ARB-V10b-***-XX_SEP-10-2007_CodeData.B1M
KG290P40-ARB-V10b-***-XX_SEP-10-2007_AlchemyData.B1P
the phone is pink KG290 made in CHINA
Old 07-19-2008, 09:53   #9 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
seems there is a general problem in lg flashing process infinity team look deeply inside what's wrong with lg models
Old 07-19-2008, 10:25   #10 (permalink)
Member: 130995
@f164
It\'s not so good idea to talk about general problem due to it\'s not exist.
It may be small bugs for one or two models and we always ready to fix bugx (if it\'s exist) but please, do not say about general problem etc. without real test report.
I hope next time you will me bore careful with your words about \"general problem\".
@plitom
Old 07-19-2008, 11:57   #11 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
@f164
@plitom
sorry to say this but i have faced the same thing with 4 lg models kp105 kp100
kg275 kg 290 so this is the idea no more
ps:sorry for my words
Old 07-19-2008, 13:43   #12 (permalink)
Member: 66841
photo of the link
S/N:801CQRN690158 KG290
http://www.fotosik.pl/pokaz_obrazek/...2ffe253b0.html
Old 07-20-2008, 23:22   #13 (permalink)
Member: 130995
@f164
Phones that you talk about has different hardware problems.
What was the problems exactly ?
@plitom
if problem still exist you can try to use the next files:
http://rapidshare.com/files/13121796...-2007.RAR.html
http://rapidshare.com/files/13122036..._2007.zip.html
Old 07-21-2008, 16:18   #14 (permalink)
Member: 66841
the second link does not work, and these files are a different type, such as their use?
Old 07-21-2008, 17:02   #15 (permalink)
Member: 130995
It\'s original LG files for original flasher
lg kg290 white screen after flash BIJOU8420 VygisToolbox 2 01-13-2012 14:22
LG KG290 after flash hange on starting LG KG290 logo ..::proudcracker::.. VygisToolbox 8 06-15-2009 20:53
LG KG290 dead after unlocking gumoff Infinity-Box 6 03-18-2008 21:15
lg kg300 dead after flesh dimitron Infinity-Box 10 03-21-2007 11:46
LG G3100 Dead after fleshing mohangbvk HWK 1 02-01-2006 07:03
Page generated in 0.36436 seconds with 9 queries
