11-26-2015, 17:58 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Wainting update CM2RKT Card found: S/N : 1BC6232F , v0129 Chinese Miracle II [RKT Module] v 1.0 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK2928 Read Info Ok! Operation : ReadInfo [ v1.0 ] ======= Flash Info : Channel : 0x00 FlashType : 98DE849372 FlashSize : 0x0000000200000000 FlashCaps : 4194304/16384/46/40/1 ======= Device Info : CPU : RK2928 Android : v4.4.2 Project : eng.luob.20140509.152255 Name : rkr70ht Brand : SW Device : rkr70ht Model : Tablet 2704 Read Info Ok! Elapsed: 00:00:05 Operation : Read Flash [ v1.0 ] Collect InitData ... Reading now ... Reading : PARAMS Reading : MISC Reading : KERNEL Reading : BOOT Reading : RECOVERY Reading : BACKUP Reading : CACHE Reading : USERDATA Reading : SYSTEM Reading : DATABK Reading failed! Send report to support with all logs! Elapsed: 00:04:19 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK2928 Read Info Ok! |
11-26-2015, 21:40 | #4 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | Other model RK2928: Operation : ReadInfo [ v1.0 ] ======= Flash Info : Channel : 0x00 FlashType : ADDE94EB74 FlashSize : 0x0000000200000000 FlashCaps : 4194304/16384/42/40/2 ======= Device Info : CPU : RK2928 Android : v4.1.1 Project : 20130907.085925 Name : rk2928sdk Brand : BRAVVA Device : rk2928sdk Model : BV4000 Read Info Ok! Elapsed: 00:00:06 Operation : Read Flash [ v1.0 ] Collect InitData ... Reading now ... Reading : PARAMS Reading : MISC Reading : KERNEL Reading : BOOT Reading : RECOVERY Reading : BACKUP Reading : CACHE Reading : USERDATA Reading : SYSTEM Read Ok! Firmware size : 543 MiB Saved as : RK2928__BV4000__rk2928sdk__20130907.085925.irkfw Done! Elapsed: 00:04:21 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK2928 Read Info Ok! Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Operation : Read PatternLock [ v1.0 ] Reading PatternLock ... PatternLock : Not set! Done |
