12-20-2006, 20:00 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Hidden in Gomez Cell Age: 62
Member: 86179 Status: Offline Sonork: 1615814 Thanks Meter: 10 | @Infinity Support Moto C261 But now in the band settings can choose only 900, 1800 or 900/1800 and guess what i need 1900 any solution? Thanks |
12-20-2006, 20:35 | #3 (permalink) |
Member: 86179 Status: Offline Sonork: 1615814 Thanks Meter: 10 | read! @sniper I would not know where to read the answer to my question in your link. Just to be clear. I have no "blinking" ,unlock or restarting problem. Phone starts up normal with sim card in so unlock was correct. The only problem is that in the Band menu there is no 1900 band to select, probally the flexversion. Would be pitty to have to flash a locked flex into the phone. Maybe there is a solution to just make the 1900 band visible in the menu |
12-20-2006, 21:31 | #4 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: insane in da mad brain Age: 46
Member: 154522 Status: Offline Thanks Meter: 48 | Quote:
12-20-2006, 23:23 | #5 (permalink) | |
Are you sure that your phone was 1900 before unlock ? If you are sure: try to use different Flex files from support area (but use only ordinary Flex files, not use Flex files with "Locked" text in file name). | |
12-21-2006, 00:13 | #6 (permalink) |
Member: 86179 Status: Offline Sonork: 1615814 Thanks Meter: 10 | c261 @Freakyass: Thanks this is an aswer that explains why it won't work. @InfinitySupport: Thank you also, as always good supporter And the imei was 35 etc so i assume will not work on 1900 Phone back to customer |
04-02-2007, 17:52 | #7 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: HUR / R.S Age: 39
Member: 21750 Status: Offline Sonork: 100.62509 Thanks Meter: 73 | Quote:
i unlocked with smart clip and band selection only 850/1900 i flash it with euroup flash and flex but now band selection 850 1900 850/1900 any way to get 900 / 1800 mhz ? | |
04-02-2007, 19:46 | #9 (permalink) |
Member: 21750 Status: Offline Sonork: 100.62509 Thanks Meter: 73 | if we change the filters like c139 it will work any body can help with the place of the filters for the network to replace it ? the proplem most of the phone glowed with white **** i can't see well where is the filters for the network to change it |
12-06-2007, 18:19 | #10 (permalink) |
Crazy Poster Join Date: Mar 2007
Member: 472815 Status: Offline Thanks Meter: 6 | hi. all fri. try this (http://gsmph.com/forum/vbb/showthrea...ight=moto+c261 ) |
