10-25-2015, 13:49 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: JESSORE, BNGLADESH. Age: 39
Member: 939797 Status: Offline Sonork: 100.1601089 Thanks Meter: 359 | walton primo gf mt6582 virus remove problem 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35575A4D420117D2CAF4B071 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0000 , OEM : 0000 [eMMC] : FLASH_INF : [eMMC] : FLASH_CID : 00000000000000000000000000000000 [eMMC] : FLASH_EXT : 00000000/00000000 [eMMC] : FLASH_LEN : 0x0000000000000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND Flash not supported yet! Done! Elapsed: 00:00:10 Reconnect Power/Cable! sir jaydi why software say NAND Flash not supported yet! ? this is emmc. |
10-25-2015, 14:12 | #3 (permalink) |
Member: 939797 Status: Offline Sonork: 100.1601089 Thanks Meter: 359 | when read nv file than show Operation : Read NVRAM [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35575A4D420117D2CAF4B071 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D420117D2CAF4B071 [eMMC] : FLASH_EXT : 00200000/00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : Can't identify BB version! Read Ok, MT6582_eMMC.spnv saved Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
10-25-2015, 14:15 | #4 (permalink) | |
Member: 939797 Status: Offline Sonork: 100.1601089 Thanks Meter: 359 | Quote:
10-25-2015, 14:18 | #5 (permalink) |
Member: 939797 Status: Offline Sonork: 100.1601089 Thanks Meter: 359 | but nv read not work perfect.again restart and same massage ( [Info] : Can't identify BB version! Read Ok, MT6582_eMMC.spnv saved). |
10-25-2015, 15:00 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | There just some connection / power problem. Charge battery fully, then do operation again. Can't Identify - DO NOTHING with BB in phjone, it just help correctly name nvram file for easy use. |
10-25-2015, 15:15 | #7 (permalink) |
Member: 939797 Status: Offline Sonork: 100.1601089 Thanks Meter: 359 | @JayDi thanks for quick replay and do it dc power 4.2 volt but same(NAND Flash not supported yet!) . when software restart than work.thats not major problem ,just information for you. |
