03-26-2017, 15:37 | #1 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Paris Age: 28
Member: 2483507 Status: Offline Thanks Meter: 81 | Walton Primo GH6 pattern Not found :-( but phone has pattern lock. Code: Code: Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050756F7E4C7337B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050756F7E4C7337B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x473C55E2197D7A1EF3EAA08A0CD2176C INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... [Info] : PatternLock Not Set! [Info] : DP Lock not set! Done! Elapsed: 00:00:15 Reconnect Power/Cable! Code: Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050756F7E4C7337B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050756F7E4C7337B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x473C55E2197D7A1EF3EAA08A0CD2176C INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! LSSNG Ok! LSSNP Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
03-26-2017, 15:58 | #2 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | because some device not support .. that devices will support if u write your own code ,, |
The Following User Says Thank You to malka4u For This Useful Post: |
03-26-2017, 17:19 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It because phone on ANDROID 6.X or newer. There is another system of code storage. Rest UserCode is universal. |
