03-03-2015, 09:21 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Warning!!!!! FlashFile Size Is Bigger, Than eMMC Space! It Can Be Damaged Or Wrong Code: Start at : [3/3/2015 / 1:04:59 PM] Operation : Check / Read Info [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 39 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 150100534A5330304D00855A21F4AF67 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:07 Reconnect Power/Cable! Finish at : [3/3/2015 / 1:05:07 PM] Load File File_Info : hexing75_jb FileVersion : MT6575 Load File Ok Start at : [3/3/2015 / 1:06:42 PM] Operation : Flash [ v1.13 ] ======= Flash Files set for flashing : [ MCU ] : MT6575__GT-S7582__ALPS.JB.MP.V1.16__Android_4.2.2__20141230_094518.ispff and when try to write same dump file with another same phone get warning Warning!!!!! FlashFile Size Is Bigger, Than eMMC Space! It Can Be Damaged Or Wrong can someone tell me where is the problem ? can i ask once again when team will add this chip for factory firmware Reading ? |
03-03-2015, 09:34 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello, can you show no log while you try flash this file to another phone? Mostly - that mean FlashIC are wrong and phone will not work with this FW and will be dead. Factory reading - without DSP BootLoader - it mostly useless as factory FW. And those ugly ancient 6575 very strange. At now working with them. |
06-25-2015, 13:45 | #3 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Quote:
WBR | |
03-28-2017, 10:28 | #4 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2692475 Status: Offline Thanks Meter: 4 | qmobile a290 dead i have same issue with qmobile a290, i flashed it with scatter file by sp flash tool and it gave error of PMT , so i changed the otion to format+download , this time it flashed but phone got dead after this, i saw a video and flashed it by BIN file, with cm2, it gave me the error, Warning!!!!! FlashFile Size Is Bigger, Than eMMC Space! It Can Be Damaged Or Wrong and it asked if i still want to continue , and i icked YES , so it did flash A290 but still phone is dead :-( , very sad, any solution? |
03-28-2017, 19:19 | #5 (permalink) | |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | Quote:
http://forum.gsmhosting.com/vbb/f296...flash-2028746/ Best Regards | |
