Old 10-17-2015, 06:43   #1 (permalink)
Member: 364927
Thanks Meter: 17
jaydi sir plz help me mtk 6572 nand flash file not read.
Card found : S/N : 89497B78 , v0129
Chinese Miracle II [MTK module] v 1.34
Operation : Check / Read Info [ v1.34 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 009800BC009000660076001600080000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Info read not done Erased phone or unsupported FlashIc?
You can change settings : Settings -> Other -> NAND init Mode
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
Old 10-17-2015, 07:33   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Wait for phone...
Phone found! [ 22 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:12
Hello,
Answer already in log- change settings : Settings -> Other -> NAND init Mode
First make sure about "ReadInfo" passed fully!
Change Nand Init mode until Read Info is success and then software will read FF.
Br.
Old 10-17-2015, 07:58   #3 (permalink)
Member: 364927
Thanks Meter: 17
already cheked one by one & auto but same
Wait for phone...
Phone found! [ 22 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:08
Old 10-17-2015, 08:24   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. What model it is ?
Old 10-17-2015, 08:30   #5 (permalink)
Member: 364927
Thanks Meter: 17
q mobile x11 wcdma/3g
Old 08-10-2016, 08:04   #6 (permalink)
Member: 1589971
Thanks Meter: 97
Mr jaydi what's wrong
Operation : Check / Read Info [ v1.45 ]
Wait for phone...
Phone found! [ 87 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Settings for BROM configured!
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164040501A1ED4351FF
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:11
Oppo R1001
hang on Logo
Old 08-10-2016, 09:51   #7 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Wait for phone...
Phone found! [ 87 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:11
Oppo R1001
hang on Logo
Hello,
Use latest version and connect phone without pressing any keys.
Br.
Infinity Box Support Team.
Old 08-10-2016, 18:01   #8 (permalink)
solusi hp's Avatar
Member: 2162000
Sonork: 100.1670061
Thanks Meter: 205
no need update for several oppo phone series all many tested all operation must press vol up. more fully info when first operation. make some test from tab make sure not have hardware problem with emmc inside. many buggy from oppo R*** with emmc inside.
The Following User Says Thank You to solusi hp For This Useful Post:
Page generated in 0.23524 seconds with 8 queries
