Old 06-17-2006, 16:09   #1 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Thanks Meter: 100
VS2 Restarting
Hello,
I received a VS2 to unlock, all ok, went to infinity, like many times before, to do it. It starts ok, but in the end, gives msg "unlock impossible", or something like that.
So, I tried unlocking with Panasolar, after unlocking it seems to be alright. But when testing the phone, I discovered that is was restarting, when pressing center button, top left or top button. To solve that, I flashed with Infinity all files, no problems during flashing, but even after flashing problem is still the same.
Is there any way to get this matter solved using infinity?
br
Old 06-17-2006, 19:56   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
I think it's need to make the next steps:
1. talk with panasolar support about the problem
2. check phone hardware
3. if no results after steps 1. and 2.: send me Log file after unlock try and we will see what to do.
Old 06-19-2006, 19:32   #3 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Thanks Meter: 100
hello,
1 - they said clip wouldnīt do that, and itīs my problem;
2 - hardware is ok, phone was working perfectly before unlocking;
3 - image attached, pls give a hand.
br
Old 06-19-2006, 23:55   #4 (permalink)
Member: 130995
Hi,
try this: http://forum.gsmhosting.com/vbb/showthread.php?t=307569
and let me know about results (and log file).
Old 06-20-2006, 02:36   #5 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Thanks Meter: 100
hello,
now unlock worked wonderfully, but phone still restarting. this problem only occurs when entering menus, main one or message, from main screen. if none of these buttons are pressed (left, top left, up, center), phone works ok, even calls can be made.
but during a call, i can access menus, and even type a sms. camera also works normally. that´s a very weird situation, I´ve unlocked dozens of those phones, and never saw something like that, and tryed everything I could think. if u have any shot, i´d be very glad, phone owner is a pain in the *** who calls every 5 minutes..
thanks for ur attention.
br
__________________________
log file below:
Phone must be in TEST-MODE: * + # + Power
Connecting, wait...
Phone found, wait...
Connection Ok
Unlocking...
Imei: 3568010042xxxxx
SEC ver: 00.11Sg(0002)
SW ver: NBG_LEOPARD_05.19.02SMARTI_SDB1SGOLDliteV1
MMI ver: Mmi:VS2-VH09,Jan13200611:10:35
auto-detection in progress...
Unlock code: 21560235
EXACTLY STEP-BY-STEP:
1. insert ANY sim-card into phone
2. switch-on phone
3. switch-off phone
4. switch-on phone, press 52824**
5. enter unlock code
6. switch-off phone
startup mode confirmed
Done
Finished
Old 06-20-2006, 08:35   #6 (permalink)
Member: 130995
Hi,
I think you have a reason to check hardware. It's first time when I hear about this kind of damage. If phone was flashed with full set of files w/o errors I think need to check HW.
Old 06-20-2006, 16:41   #7 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Thanks Meter: 100
well, checked pcb very well with a microscope, couldn´t find anything wrong, besides, as said, checked phone before unlocking, and it was working fine.
tried to flash it again, and can´t anymore, already switched cable, still same thing... gonna buy another phone today so I can get rid of this phone owner, but if you have something new, please let me know. anyway, nice update on last pana1.24a, really better!
br
Try #1
[Infinity Box] v.1.24A
Loading, wait...
S/N: 0379:0108
Standard firmware detected
Wait...
Current device: X60,X66,X68,X77
Ready
COM1 ready
Current device: VS2,VS3
Loading file [version 01]...
VS2_VS3_VA47_Main.2CM.bin Loaded
VS2_FFS1_AP_R03.2CF.bin Loaded
VS2_VS3_GP1108.2CG.bin Loaded
VS2_FFS2_AP_R03.2CS.bin Loaded
Testing COM1 at 115200...
Device: VS2,VS3
Checking data, wait...
Action: Flash write
Boot...
Press Power button now !
Checking...
Boot answer: 02
Boot Done
Set Baud...
Set Baud Done
Connecting...
FLASH ID: 0089:880D
Connecting Done
Check free space...
Flash chip supported
Check free space Done
Write...
Reset...
Done
Writing: Firmware
Repair write error [A0121000]...
Err: write failed[A0020000]
Err: erase not confirmed
Write Failed
Finished
Remove/Install battery now !
Time used: 132 sec
Try #2
Loading, wait...
S/N: 0379:0108
Wait...
Ready
VS2_VS3_VF10_Main.2CM.bin Loaded
Device: VS2,VS3
Action: Flash write
Boot...
Checking...
Boot answer: 02
Boot Done
Set Baud...
Set Baud Done
Connecting...
Connecting Failed
Finished
Time used: 16 sec
Try #3
Device: VS2,VS3
Action: Flash write
Boot...
Checking...
Err: wrong Boot answer2:
Boot answer: 00
Err: unknown hardware
Boot Failed
Finished
Time used: 5 sec
E72 keep restarting ..... any help with hardware solution?? abu_nairoukh Nokia Hardware & Hardware Repair 4 12-14-2010 11:10
need help master manole n95-8gb write screen restart haslyn MXKEY Nokia Flasher and Unlocker (by Alim Hape) 15 03-30-2010 10:56
Restart your Friend's cell phone using sms kashem403342 Nokia Hardware & Hardware Repair 3 03-29-2010 13:45
Restart your Friend's cell phone using sms kashem403342 Nokia Base Band 5 ( BB-5 ) 0 03-29-2010 11:57
p900 restart restart restart restart clinic*mobile Sony Ericsson 2 05-31-2004 11:33
Page generated in 0.17262 seconds with 10 queries
