What Is That Error Plz Infinity Team Samsung Clone J310H/Ds After Writing Wrong Firmware...... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E355530304D00F7BC2ECBAF71 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 DRAM_INIT_REQ_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:33 Reconnect Power/Cable! |
On Initialize Memory Usb Auto Dissconnect |
damaged by wrong firmware try with full erase or format then updat again hope u get succes |
Still Same Quote:
