Old 08-13-2007, 09:31   #1 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
N77 ChineseMiracle supported no need any update
ChineseMiracle best working software for china models..
here is log not like another tools who anonuse support but no working solution.
WARNING ! Settings will be cleared, user data erased, Imei set to default !
Do you want to continue ?
COM8 [VCP0] selected
Device: Autodetect
Checking data, wait...
advanced flash detection active
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 89881500010001:89881500000000
flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Check space...
device parameters autodetection in progress..
total flash region size: 01000000
detect device identification, method #1...
detection phase #1...
detect device parameters finished
structure: 2nd [standard] (or higher) generation
protocol ver: 04
ver. sw1: F421M02_PCB01_GPRS_MT6226_S01.M_RF4230404_M01001_V 1_0_0_1M0608.BIN
ver. sw2: M.RF4230404.M01001.V1.0.0.1M0608
ffs offset/size: 00F00000/00100000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
eeprom found near: 00F00000
Detected eeprom address is non-standard: 00F00000
If you are not sure that detected address is correct:
1. press "NO" right now
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom address confirmed by user
detecting eeprom size...
eeprom size: 00100000
eeprom chip: 00
eeprom area detected[00000000]: 00F00000-00FFFFFF
reading [eeprom[F421M02_PCB01_GPRS_MT6226_S01.M_RF4230404_M01001_V 1_0_0_1M0608.BIN]]...
file saved: backup_eeprom[F421M02_PCB01_GPRS_MT6226_S01.M_RF4230404_M01001_V 1_0_0_1M0608.BIN]_20070812-191901.B0E.bin
Check space Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
Finished, time used: 59 sec
Remove/Install battery now !
flash file will be in support area asap ..
Old 08-27-2007, 17:11   #2 (permalink)
Member: 128745
Thanks Meter: 16,936
stanner_austin thankyou for the information
Old 08-28-2007, 11:38   #3 (permalink)
Member: 49752
Thanks Meter: 6,085
one more boss.
black berry clone.. skywork name on it..
19200
Connecting, wait...
high speed disabled
Boot Done
Initialize...
flash: 98004900000002:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Check space...
structure: 2nd [enhanced] (or higher) generation
identification data Ok
identification data backup saved: id.E3C19E67.[SKYWORTH26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN_8F20795E].rpl
identification detection finished
device-id: E3C19E67
protocol ver: 04
ver. sw1: SKYWORTH26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN
ver. sw2: MAUI.05C.W06.16.MP.V7
ffs offset/size: 00E00000/00200000
eeprom found near: 00E00000
eeprom size: 00200000
eeprom chip: 00
eeprom area detected[00000000]: 00E00000-00FFFFFF
reading [eeprom[SKYWORTH26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN]]...
file saved: backup_eeprom[SKYWORTH26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN]_20070824-213137.B0E.bin
Check space Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
file saved: backup_system_log_E3C19E67_SKYWORTH26_05C_PCB01_GP RS_MT6226_S01.MAUI_05C_W06_16_MP_V7.BIN_8F20795E_2 0070824-213148.B0X.bin
Finished, time used: 78 sec
Old 08-28-2007, 12:23   #4 (permalink)
REMO's Avatar
Member: 49339
Thanks Meter: 93
Thanks For Sharing Sir.
Old 08-28-2007, 17:07   #5 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
Thx 4 Keep Us Know...nice From Infinity
Old 03-12-2008, 14:17   #6 (permalink)
Member: 462382
Thanks Meter: 9
hi 2 all need n77 flash file
Old 03-12-2008, 14:36   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
You can download many N77 files from Infinity-Box support area.
Old 03-12-2008, 15:47   #8 (permalink)
Member: 419703
Thanks Meter: 123
No Need any activation or any box..... UnlockByLogs All UnlockByLogs Server 3 12-16-2009 07:28
Long time no see any updates nasagih SpiderMan 1 08-15-2009 23:57
new tested soft fix pm120 bb5 no need any box RamSon83 Nokia Base Band 5 ( BB-5 ) 22 07-03-2009 11:40
C417 samsung unlock by code no need any soft. kmaxmax UST Pro II 1 05-22-2009 11:24
new s.e. logger with all new updates no need any box. RahulGSM Main Sales Section 0 08-19-2005 07:39
Page generated in 0.24246 seconds with 9 queries
