Old 03-08-2008, 16:34   #1 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 97
flash file for cm
i need flash file for below mentoined model .dual sim phone , brand name mabao like n98
Hardware version: MT6226, E02
Hardware version: M500Z_05C_HW
Software version: E551_C4QF8.01.0_26S0
Software date: 2005.04.12
Barcode: MT012345678901234567
please tel wich flash file i want to download from infinity support
my problum is after fss format both sims are not working same time
Old 03-08-2008, 19:49   #2 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
you must post log
history of the mobile
wot method you use for format
Old 03-09-2008, 07:46   #3 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 97
Originally Posted by c_ahmad79 View Post
you must post log
COM3 [VCP5] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031552:F861
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: E551_C4QF8.01.0_26S01
Version: M500Z_05C_HW
detecting structure #2...
done
60 byte(s) read
imei: 13579024681122
connection Ok
building list...
done
items to clear: 166
144 of 166 items cleared
building list...
done
3 items remains
Finished, time used: 133 sec
Remove/Install battery now !
Old 03-10-2008, 11:26   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please read complete phone information.
this way our advice for flash file will be more accurate
Old 03-11-2008, 12:23   #5 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 97
general infomation
Action: read information
Phone should be Switched ON !
Connecting, wait...
imei: 135790246811220
Finished, time used: 61 sec
Power off phone now !
Old 03-11-2008, 12:29   #6 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 97
detailed infomation
COM3 [VCP2] selected
Device: Autodetect 6205-6227 NOR
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
baud autodetection active
19200
Connecting, wait...
CPU: MT6226
chip: 0031552:F861
high speed disabled
boot step size: 0002
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.8DC48A86.[E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN_6ABFFCDD].rpl
identification#1 detection finished
device-id: 8DC48A86
identification#1 protocol ver: 04
ver. sw1: E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN
ver. sw2: E551_C4QF8.01.0, 22034095
ffs offset/size: 00800000/001FF000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00800000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
Detected eeprom/ffs address is non-standard: 00E00000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00E00000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _8DC48A86_E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN _6ABFFCDD_20080311-172724.B0X.bin
Finished, time used: 222 sec
Old 03-11-2008, 16:13   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
You need to use flash file with version similar to this:
Old 03-12-2008, 10:08   #8 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 97
Originally Posted by InfinitySupport View Post
Hello,
how to identyfy sw2 file please explain me sir
Old 03-12-2008, 10:26   #9 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 97
pease ignore above question
Old 03-12-2008, 15:25   #10 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 97
Hello,
i seach support site and down loaded there are 2 files but little diferance
1. CM_Cect-V909_Nckia-6300c-2sim_E551_A_E551_GPRS_MT6226_S01.01_1_16m_En_Cn_Cn .B0M
2. CM_DaullSim-CPU1E551_C7ARVBT_E551_GPRS_MT6226_S01.01_1__16m_En _Ru_Fr_Vn.B0M
which file suitable for filash?
Old 03-12-2008, 15:32   #11 (permalink)
Member: 130995
You can use files one by one and see results each time.
Guide Me For Study Motorola Flash File To Choose Corect Flash File For Reflash Set shahi Motorola P2k 2 03-10-2008 14:23
Guide Me For Study Motorola Flash File To Choose Corect Flash File For Reflash Set shahi Motorola Hardware Repair 0 11-16-2007 07:54
how can ı use patch files martech flash files for change imei MONSTER49 Martech CLIP / Box / Key 5 02-07-2007 20:33
Need flash file for dejan 1.05 or full flash for 6250 with polish language Rafal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 08-10-2002 20:13
c2r flash file for c25..or xbi file CellM@n x1x to x45/x50 0 11-12-2001 18:27
Page generated in 0.20479 seconds with 9 queries
