what a problem........... COM3 [VCP0] selected module v3.52 Device: I-Mobile-518 Checking data, wait... Action: write flash NAND write: Firmware IMobile-518_DARTS6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W 06_24_MP_V23_En_Cn.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: DARTS6228_05C_BOOTLOADER_V005_MT6228_MAUI_05C_W06_ 24_MP_V23.bin nfi area detection finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6228:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0007]: 00EC:00F100800015 [SAMSUNG] K9F1G08X0M chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: MAUI.05C.W06.24.MP.V23 detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: DARTS6228_05C_BOOTLOADER_V005_MT6228_MAUI_05C_W06_ 24_MP_V23.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: DARTS6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W06_2 4_MP_V23.BIN project-id: MAUI.05C.W06.24.MP.V23, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] type TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: DARTS6228_05C_BOOTLOADER_V005_MT6228_MAUI_05C_W06_ 24_MP_V23.bin nfi area detection finished: Ok startup code area #1 check... error: done number of cores: 2 loading files... number of areas: 2 done write... error: can not write flash: 0BBF:S_DA_RAM_ERROR error: last error: 0BBF:S_DA_RAM_ERROR Disconnect... done Finished, time used: 1 min 27 sec Remove/Install battery now ! how to solved.............. |
hello! what is phone history? what was phone condition before flash and after? can you be more detailed? |
