Old 12-17-2007, 14:19   #1 (permalink)
kaaniletisim's Avatar
Member: 79065
Sonork: 100.1646746
Thanks Meter: 79
what problem ke970
what problem ke970 flash
Old 12-17-2007, 14:46   #2 (permalink)
Member: 253794
Thanks Meter: 6
too me, what is it??????
Old 12-17-2007, 14:51   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Just try to press and HOLD phone "Power" button long time during boot process.
Old 12-17-2007, 17:49   #4 (permalink)
ElectronTelecom's Avatar
Member: 421660
Thanks Meter: 212
Tnx Infinity Team
Tnx Infinity Team.Modul yes working
Old 12-17-2007, 18:23   #5 (permalink)
Member: 421660
Thanks Meter: 212
Flash Write Done
Old 12-24-2007, 10:22   #6 (permalink)
rampe's Avatar
Member: 129016
Thanks Meter: 6
I am getting same problem
Anyone body knows a workaround this connection problem,?
However I can read the phone fine with the box and cable so it is not a cable issue....
Old 12-24-2007, 10:52   #7 (permalink)
Member: 130995
Solution for "the same" problem is: press and HOLD phone "Power" button long time during boot process.
Old 12-24-2007, 11:20   #8 (permalink)
rampe's Avatar
Member: 129016
Thanks Meter: 6
thank you but more error
this is log >
COM38 selected
Device: LG KE970
Checking data, wait...
Action: flash write
Boot...
Press Power button now !
loading...
error: can't run main loader: 00AA
boot answer: 00
error: unknown hardware
Boot Failed
Finished, Remove/Install battery now !
Time used: 8 sec
Any help please
Old 12-24-2007, 11:43   #9 (permalink)
Member: 130995
This log looks like you did not hold Power button. It's need to press and hold Power button pressed during software send boot to phone.
Old 12-29-2007, 14:45   #10 (permalink)
Murat Bekar's Avatar
Member: 2088
Sonork: 100.1630154
Thanks Meter: 57
same problem with ke790. ( I hold power button during flash process )
there may be some bugs
B.R
Old 12-29-2007, 16:16   #11 (permalink)
Member: 130995
Hello,
It's need to press and hold phone Power button. Please, repeat process again and finally you will have a success.
Old 12-29-2007, 16:39   #12 (permalink)
Member: 2088
Sonork: 100.1630154
Thanks Meter: 57
using pana01 1.35 with rj45 kg800 cable
I can read phone imei etc but I can not read eeprom nor I can not flash phone firmware
always hardware failure etc. I hold power button until it sais release button. tried several times but it still gives errors.
I also tried with pana01 1.34 version and it is also same.
B.R
Old 12-29-2007, 16:44   #13 (permalink)
Member: 2088
Sonork: 100.1630154
Thanks Meter: 57
loading...
Release Power button now
boot answer: 00
Boot Failed
Time used: 9 sec
tried about xxx times I am in doubt from myself.
B.R
Old 12-29-2007, 18:06   #14 (permalink)
Member: 2088
Sonork: 100.1630154
Thanks Meter: 57
interesting .
pana01 1.35 working with ANOTHER ke970 . ?
I think there is a bug in the software.
B.R
Old 12-29-2007, 18:24   #15 (permalink)
Member: 130995
Hello,
Please, check connector of first KE970. Probably bad contacts in connector.
Also, please, read eeprom from your phone and send to [email protected] for future development.
Thanks !
problem ke970 flash DEHGHAN Z3X-Team Products 4 02-11-2010 14:26
What about Ke970 ? newchief Z3X-Team Products 16 01-07-2010 18:46
Communication problem ke970 judas FuriousGold 7 07-10-2007 22:34
cant read field 251 for rc912 whats problem kenwood Infineon C16X M51 & ARM7 M52 BASED 3 04-21-2003 20:46
Page generated in 0.27196 seconds with 10 queries
