03-24-2021, 16:05 | #1 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | Who can please explain - DA : BOOT 2ND DA FAILED! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM40) MODE : BOOTROM PORT : 40 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT8167 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : MEID : 87D6994A7F00350A9E5772FC774A084E BROM : SecLevel : 0x000000E0 BROM : SecMode : EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT8167 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0006 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH MISMATCH Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Can you please let me know where a problem might be? Thank you |
03-25-2021, 02:57 | #7 (permalink) | |
No Life Poster Join Date: May 2008 Location: philippines
Member: 773960 Status: Offline Thanks Meter: 529 | Quote:
its DA problem you need to find DA that suits to that model | |
03-25-2021, 08:34 | #8 (permalink) |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Hi, with the update of the infinity 2.21 mtk module it is not necessary to use files from abroad or from the internet, as you open the module you leave it as it is, tick Ssla, Hwreport, identify the phone, you also have to know or try according to mtk processor and phone security, preloader mode or broom mode connection, remember to force broom mode by pressing the volume keys. Both the acer and asus, try the internal file Da.swec.bin. You have to try and test. Greetings. BR |
03-25-2021, 08:37 | #9 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thanks all for replies.To sum up: I have tablet Acer Iconia ONE 10 B3-A40 model A7002 ( in the first post I wrote A3-B40 by mistake). So the correct is Acer B3-A40 model A7002. It does not start. So I wanted to identify first, but identification finished with error DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH MISMATCH Error : Fail to init protocol! as you can see from the log here again Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM40) MODE : BOOTROM PORT : 40 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT8167 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : MEID : 87D6994A7F00350A9E5772FC774A084E BROM : SecLevel : 0x000000E0 BROM : SecMode : EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT8167 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0006 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH MISMATCH Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Where can be a problem? Does anyone have a firmware for that tablet Acer Iconia One 10 B3-A40? Thank you |
03-25-2021, 08:37 | #10 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thanks all for replies.To sum up: I have tablet Acer Iconia ONE 10 B3-A40 model A7002 ( in the first post I wrote A3-B40 by mistake). So the correct is Acer B3-A40 model A7002. It does not start. So I wanted to identify first, but identification finished with error DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH MISMATCH Error : Fail to init protocol! as you can see from the log here again peration : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM40) MODE : BOOTROM PORT : 40 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT8167 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : MEID : 87D6994A7F00350A9E5772FC774A084E BROM : SecLevel : 0x000000E0 BROM : SecMode : EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT8167 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0006 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH MISMATCH Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Where can be a problem? Does anyone have a firmware for that tablet Acer Iconia One 10 B3-A40? Thank you |
03-25-2021, 08:50 | #11 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Quote:
https://forum.gsmhosting.com/vbb/f29.../#post13375907 | |
03-25-2021, 08:54 | #12 (permalink) | |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
BR | |
03-25-2021, 14:17 | #14 (permalink) | |
This image is only for WW_GEN1 SK Date:2018/02/27 Version:RV09RC01.WW.GEN1 Vendor:Acer Size:1,804.6 MB https://global-download.acer.com/GDF...C=ACER&SC=PA_6 -------------------------------- This image is only for WW_GEN1 SKU Date:2020/05/14 Version:RV02RC01.WW.GEN1 Vendor:Acer Size:1,790.8 MB https://global-download.acer.com/GDF...C=ACER&SC=PA_6 --------------------------------- This image is only for WW_GEN1 Date:2018/10/08 Version:AV0N0.B3-A40.RV0ARC01.WW.GEN1 Vendor:Acer Size:1,775.6 MB https://global-download.acer.com/GDF...C=ACER&SC=PA_6 -------------------- | |
03-26-2021, 09:57 | #15 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thank you for your reply and the link I tried to flash it but I can not flash system image file from the firmware. There are files : system.new.dat, system.patch and system.transfer.list but none is flashed eventhough I choose system to be flashed. Where can be a problem? here is the log 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT8167 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2044 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC_A10L2_new.bin AGENT : Found MT8167 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 45010044463430333201C314AD8A246F EMMC: VEN : SANDISK | OEM : 01 | DEV : DF4032 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT8167 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 26F0D2D8C9A961F6653F2BE3DAFFC70D DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000004C80000 : 0x0000000001100000 Erase : 0x0000000006D80000 : 0x0000000000080000 Erase : 0x0000000007600000 : 0x0000000001500000 Erase : 0x0000000008F00000 : 0x0000000002100000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : LK Write : LK2 Write : BOOT Write : TEE1 Write : TEE2 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:00:58 Reconnect Power/Cable! Is there an error in scatter file? |
